First post, by adalbert
I bought nice Toshiba T3200SXC last year very cheap from recycling company. It's one of first laptops with active matrix screen. It turned out that it was working, but had defective screen. Recently I finally found a working 10.4" TFT display so I could install it, after 3D printing some mounting adapters and soldering some cables to convert 6-bit color input on LCD panel to be compatible with 3-bit output from laptop's LCD controller. I also installed new CMOS battery (there was big 3.6v lithium battery on a cable but I installed small CR2032) and put inside two speakers taken from modern laptop (there is a lot of space inside), so I can solder them to sound card with amplifier, installed into ISA slot (this laptop has 2 ISA slots).
It has 20MHz 386SX and 387SX coprocessor in a socket.
I noticed that sometimes (rarely) computer freezes, screen turns into CGA mode and displays PARITY CHECK message.
It has 6 SIMMs installed under keyboard (easy access) and one megabyte of onboard DIP memory chips.
I tried testing memory with GoldMemory utility and it was working fine, but it only has a "quick" mode.
Then I used memtest (version 1.3) and immediately the screen starts flashing, it is full of letters and after some time an error appears (unexpected interrupt). With version 2.5 it shows unexpected interrupt after start and it halts.
The behavior is the same with or without additional memory.
Here you can see what happens when using memtest (video): https://drive.google.com/file/d/0B2rbHIj6SMlF … iew?usp=sharing
Are there any different utilities I can use to check memory? Could it be faulty coprocessor? Or even CPU?
If that's the memory, i guess that desoldering onboard chips might be helpful? Maybe it will work just with memory installed in SIMM sockets, if not, then I can solder some DIP sockets and put some different memory chips.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
