Reply 60 of 318, by ibm5155
correcting: bios clock can only be 200MHz or 180MHz
If the BIOS can switch the clock from 200 MHz to 180 MHz, then I think it is adjusting the FSB from 33.3 MHz to 30 MHz, with the CPU multiplier remaining fixed at 6x.
hmm it could be...
when I finally build my infrared cable, I'll transfer setmul into this netbook and check if the other option for slowing down the cpu by half is changing the cpu multiplier or not (or I could make some asm program for detecting the multiplier and the bus frequency, since there's the debug program inside the netbook [but in this case, I really don't know how to get that info...])
The DOS program CHKCPU should be able to determine the correct FSB and multiplier on GXm chips. Be sure to download the latest version though, as I found some issues with Cyrix 5x86 and GXm chips which the author was able to correct.
wrote:I'll transfer setmul into this netbook and check if the other option for slowing down the cpu by half is changing the cpu multiplier or not
Note that the SetMul versions I uploaded will only allow switches to be used on matching CPUs. If you want to experiment you would need a modified version.
I used speedsys and this is what it shows:
100% cpu clock : 200MHz
75% cpu clock: 142MHz
50% cpu clock: 90MHz
on chkcpu these are the only values showed:
75% cpu clock: 143.9MHz
50% cpu clock: 87.2MHz
Actually the FSB is 66 and the clock 3 acording to http://www.cpu-collection.de/?l0=co&l1=Cyrix&l2=MediaGX
EDIT: I got the dos version and now it shows the fsb is 33.2 and the clock mul 6
OK Here's what I got with checkcpu:
clock speed-------fsb------multiplier
100%---------------33-------6 (198MHz)
75%----------------24-------6 (143.8MHz)
50%----------------74.4-----6 (446,7MHz) - But I belive since it says 50% the fsb is near to 16,5 (16 * 6 = 96, and that is equal to the checkcpu32 cpu clock)
EDIT2:
Ok setting the FSB to 16 and disabling the L1 cache with setmul (now even the dos prompt is slow, even in fullscreen)
I got a cpu performance on speedsys of: 6.43 😳
and the max cpu performance as: 78.48
I've got a very special (to me) CPU. I don't know if all POD 200MMXs are like this, but all of the TR switches work on mine. I think I've worked out all the combinations:
Because my motherboard does not have any L2, this makes the TR switches exceptionally useful.
On my Pentium 120, CCD and DCD to not have any effect, which takes all 486 performance levels out of the equation.
Would be good to have a TSR which allows same by hot-keys. Some games may to have problems only on start or concrete places, while switching off the chache makes the machine too slow sometimes.
wrote:Would be good to have a TSR which allows same by hot-keys. Some games may to have problems only on start or concrete places, while switching off the chache makes the machine too slow sometimes.
Batch files have worked pretty well for me. I name them go.bat and they live in each game's folder. For example:
setmul dcd
game.exe
setmul pfe
or
setmul l1d bpd vpd
game.com
setmul l1e pfe
So the effect only lasts during that gaming session.
I looked into this some months ago, for a simple tool to turn off L1 cache. The problem is that 99% of the games out there take over the keyboard and timer interrupts. So the TSR cannot be called by timer or keyboard without using advanced tricks. PCXdump is the only program I know that has such a TSR stealth mode (not open source).
wrote:The problem is that 99% of the games out there take over the keyboard and timer interrupts. So the TSR cannot be called by timer or keyboard without using advanced tricks. PCXdump is the only program I know that has such a TSR stealth mode (not open source).
Picture grabbers, TSR game cheating software like GameWizard, etc. - control the keyboard with games run, some in protected mode games too. Maybe their sources are available.
wrote:-Pentium P54C test register "TR12" options. Parameters: BPD - Disable Branch Prediction VPD - Disable V Pipeline L1DX - Disable […]
L1DX - Disable L1 cache exclusively
CCD - Disable L1 code cache
DCD - Disable L1 data cache
PFE - Pentium Features Enable; Resets the above TR12 options to default.
The status of register TR12 cannnot be read by design.
FYI, I've come across a P55C - Pentium MMX 233MHz, that responds to all TR12 test registers. It makes this CPUs speed range smoother, especially when using CCD and DCD. And is similar to using ICD with VIA C3 Ezra CPUs.
wrote:wrote:-Pentium P54C test register "TR12" options. Parameters: BPD - Disable Branch Prediction VPD - Disable V Pipeline L1DX - Disable […]
The status of register TR12 cannnot be read by design.FYI, I've come across a P55C - Pentium MMX 233MHz, that responds to all TR12 test registers. It makes this CPUs speed range smoother, especially when using CCD and DCD. And is similar to using ICD with VIA C3 Ezra CPUs.
Awesome! I thought I was the only one with a CPU that supported the test registers. 😀 Check about 5 posts up and you'll see a chart I made documenting my speed zones. If you get an opportunity, it would be cool to see something similar for your 233MMX.
wrote:wrote:wrote:-Pentium P54C test register "TR12" options. Parameters: BPD - Disable Branch Prediction VPD - Disable V Pipeline L1DX - Disable […]
I just had a look at your table above - did you vary the FSB, or are the results for a fixed FSB? If you can vary the FSB, then you should get smoother scaling. You have a steep drop from Speedsys 123 to 21.
I also have a POD 200MMX on a Socket 5 board, and it can POST the Pentium at around 16MHz using 1x multi and 16MHz FSB. Moreover, the board can also use Turbo to slowdown, as well as these test registers.
I need to do more tests with this Socket 7 233MMX, it has a very smooth range, where all the registers respond significantly - from least to most: VPD, BPD, CCD, DCD and L1D. I've also tried L1DX, but it seems to behave the same as L1D...
wrote:I just had a look at your table above - did you vary the FSB, or are the results for a fixed FSB? If you can vary the FSB, then you should get smoother scaling. You have a steep drop from Speedsys 123 to 21.
Fixed FSB and multiplier. On the system used in that chart, I have no way to change the FSB or multiplier except by jumpers. And the whole point of SETMUL (to me) is to be able to change speeds through software, without having to open the case. So that chart is the speed profile running at 200Mhz
wrote:I also have a POD 200MMX on a Socket 5 board, and it can POST the Pentium at around 16MHz using 1x multi and 16MHz FSB. Moreover, the board can also use Turbo to slowdown, as well as these test registers.
I thought the POD was multiplier locked (and I've never seen 1x as an option--1.5x is the lowest multiplier I've seen on socket 5), and how do you have a 16Mhz FSB? Typically the only options are 50, 60, and 66.
wrote:I need to do more tests with this Socket 7 233MMX, it has a very smooth range, where all the registers respond significantly - from least to most: VPD, BPD, CCD, DCD and L1D. I've also tried L1DX, but it seems to behave the same as L1D...
Please share when you do those tests. 😀 And in my case, DCD is faster than CCD.
If you don't have a turbo switch, putting a set of toggle switches on a drive bay plate to control FSB would be a useful modification.
wrote:wrote:I just had a look at your table above - did you vary the FSB, or are the results for a fixed FSB? If you can vary the FSB, then you should get smoother scaling. You have a steep drop from Speedsys 123 to 21.
As mentioned by gdjacobs, you can setup simple external switches (many ways to do this) to access internal switches like FSB, Turbo, Multi etc. in conjuction with using Setmul to gain more flexibility, and not having to open cases.
wrote:wrote:I also have a POD 200MMX on a Socket 5 board, and it can POST the Pentium at around 16MHz using 1x multi and 16MHz FSB. Moreover, the board can also use Turbo to slowdown, as well as these test registers.
The POD 200MMX behaves like the Socket 3 POD83, i.e. when the cooling fan is removed, it defaults to 1x multi. You can setup a simple switch to enable/ disable the fan, and thereby switch from 1x to 3x multi. The Socket 5 board also has hidden FSB settings as low as 16MHz, and a working Turbo header as well.
wrote:wrote:I need to do more tests with this Socket 7 233MMX, it has a very smooth range, where all the registers respond significantly - from least to most: VPD, BPD, CCD, DCD and L1D. I've also tried L1DX, but it seems to behave the same as L1D...
Yeah, will do - either here or a new thread when I get around to it.
Hi, following Clueless1 report on his Pentium Overdrive 200 MMX, I decided to try on my Toshiba Libretto 110CT, which has a Pentium 233 MMX.
I'm happy to report that all TR12 options have some effect and I obtain values very similar (slightly faster) to those reported by Clueless1.
[Speedsys]
Nothing: 176.34
VPD: 167.57
BPD: 151.19
VPD+BPD: 146.64
CCD: 38.46
DCD: 31.03
L1DX: 13.86
L1D: 13.85
*ALL DISABLED*: 12.04
This small laptop is now perfect for retro-gaming.
wrote:This small laptop is now perfect for retro-gaming.
Good deal. Cheers, man!
I moved my POD200MMX into a SS7 motherboard which let me overclock it to 83x3=250Mhz. Here is a new speed profile. One thing I noticed in this retest is that Ultima 7: The Black Gate, which is well-known to be immune to disabling L1 cache, is NOT immune to the test registers BPD (branch prediction), CCD (L1 code cache), DCD (L1 data cache), and VPD (V Pipeline). So if your CPU supports the test registers, you can disable combinations of these to get Ultima 7 to a playable speed! I wrongly assumed previously that CCD+DCD is equivalent to L1D, which proved out wrong when I ran the game with "setmul L1D" and watched it run at full speed. On my system, U7 played perfectly with the setmul switches CCD+DCD (which I give a "Performs Like" rating of 486DX-25).
I also threw in results for my real 486DX2-66 for reference. Lastly, I ranked the results by the sum of the real game benchmarks of Wolfenstein 3D, Doom, and Quake, then rated each speed zone as a ratio of the real DX2-66 game sums.
Notably, many of the synthetic benchmark results vary wildly with different combinations of these test registers.
The slowest result on the chart plays Wing Commander I too fast with few enemies on screen, and with a screenful of enemies it *almost* plays at perfect speed, still a bit too fast. So that seems to jive with the "Performs Like" rating of 486SX-20.
