First post, by j^aws
Okay, I've come to the conclusion that I'll never finish a build unless I start a thread documenting it. And even then, I may never finish it!
I thought I knew all the components for this build, but over the years, it has changed many times. I have two different boards in mind using VIA C3 Ezra-T CPUs - this is the first build. Specs:
Board: DFI ITOX3
Chipset: Intel 440BX
CPU: VIA Cyrix III, 1Ghz Ezra-T
Memory: 256MB SDRAM, CL2
On-board VGA: Chips & Technologies F69000, 2MB
The rest is subject to change...
So, this is the starting point, and some pics:
3.2 MiB
DFI ITOX3
3.13 MiB
With HSF
3.11 MiB
On-board VGA
2.72 MiB
You can see the board has a SB-Link connection, so even though there are 6 ISA slots, I won't be able to resist chucking in a sound card like a YMF724...
I don't know much about the F69000 VGA, I believe Intel bought out Chips & Technologies. It's only 2MB, and probably slow. It does have a BIOS option forcing 60Hz, which I've noticed fixing aspect ratio in ZOOL. It has BIOS options for CRT/ LCD which seems unusual. I'll probably change to another VGA card...
That heatsink fan looks quiet being 80mm, but it's noisier than some 40mm fans I have ; it's gonna go. The VIA runs cool, so I could probably get away without a fan. I can overclock the Ezra-T to 1200 Mhz easily, so may keep the fan for that.
Some temps with the CPU running at 1125Mhz:
2.42 MiB
That's it for now. I'm not sure where I'm going with this build, but I'll try to get some benchmarks later (time permitting). And any requests, please feel free to ask.
Reply 3 of 44, by BSA Starfire
Nice, thought I was the only nutter who messed with VIA CPU's 😀
Reply 4 of 44, by Tetrium
Never knew s370 boards with 6(!) ISA slots existed, looking forward to your build progressing 😀
My retro rigs (old topic)
Report spammers here!
Reply 6 of 44, by j^aws
@BSA Starfire: Yeah, I often like to take the beaten path, looking for that diamond in the rough...
@Tetrium: I came across this board by chance - I was looking for SB-Link headers, not ISA slots. Considering that header, it's like having 6 1/2 ISA slots...
@Jade Falcon: Voltage control on this board is not easy, so I'll keep stock voltage of 1.4v and overclock around that. It does 1200 Mhz easily, and at 150Mhz FSB. I have a Slot 1 build with a Slotket that has variable voltage jumpers, so that build would be better for overclocking. In my previous tests, this CPU is stable at 1300Mhz, and 1400Mhz if you don't use 3DNow!
Some quick benches with Speedsys - just used multi and FSB (all Setmul switches enabled, all caches enabled):
2.74 MiB
150x8; 1200 Mhz
2.62 MiB
100x7; 700Mhz
2.67 MiB
66x3; 200Mhz
These benches give a range from the slowest to the fastest by just using FSB via BIOS, and Setmul to change multi. Other speeds are smoothly attainable between these ranges by just using the aforementioned parameters.
In conjunction with ICD (Instruction Cache Disable), and BPD (Branch Prediction Disable), far more flexibility is possible, with a range from 286 to a Pentium II. I'll post these benches later...
Reply 7 of 44, by clueless1
Sweet. I never knew anything about the VIA cpus back in the day. Now that it's retro, there's definitely greater appreciation for the processor than I would have had when it was new. Looking forward to seeing your progress.
Reply 8 of 44, by j^aws
@clueless1: Yeah, definitely more appreciation in retrospect. I'd have to add that the discovery of VIA C3s having unlocked multipliers definitely helped, especially with SetMul maintained by Gerwin.
Some more benches, getting slower and slower in obtaining them:
3.11 MiB
66x3; 200Mhz; BPD
So, following on from the last Speedsys score of around 105, we are now at 88. I just used BPD.
3.1 MiB
150x8; 1200Mhz ; ICD
Now dropping down to 64 in Speedsys; using ICD, and full speed.
2.08 MiB
150x3; 450Mhz; ICD
Hitting 54 in Speedsys; dropped multi to 3x.
2.26 MiB
100x12; 1200Mhz; ICD
Approaching AMDs classic 5x86-133, with a Speedsys score of around 43... Changed FSB to 100Mhz.
2.25 MiB
100x3; 300Mhz; ICD
Somewhere near a 100Mhz 486; score of around 36 in Speedsys. How deep does the rabbit hole go? To be continued...
Reply 9 of 44, by gerwin
That is an interesting setup, especially the motherboard and Ezra-T CPU/ I will follow with interest! My current favorite retro system is also a VIA CPU on a i440BX motherboard.
PS: Would it be possible to save the speedsys screenshots using the .pcx export of speedsys itself, then post them here converted to .png?
Reply 10 of 44, by Tertz
The unique advantage of C3 is the possibility to have universal machine for DOS and Win9x. Faster C3 are more interesting for this. For example, on stock 1200 MHz Nehemiah gives 800 points in speedsys.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 11 of 44, by j^aws
Are you using 50MHz FSB boards? They are great for slowing down, too. The slower FSB can be used to scale even more smoothly, and also gives a lower bottom-end.
No probs - this avoids overexposed phone pics with glaring sunlight!
This board also runs Nehemiah (only tried 1.45v models), and it is faster clock-for-clock:
7.57 KiB
150x8; 1200MHz
The above is at full speed, and is around 170 pts higher in Speedsys compared to the Ezra-T (801 vs 632). The Nehemiah also has a slower bottom-end when disabling all caches, BPD etc., but it doesn't scale as smoothly; it has a large gap from around 15 pts - 130 pts in Speedsys (around the range of 486-33 to PI-133). It would still make a good all-round machine.
Some more Speedsys tests using the Ezra-T - I last left this at around a 486-100 MHz level, scoring 36pts. The following is with L1 disabled (no L2 for Ezra):
7.21 KiB
150x8; 1200MHz; L1D
This is the fastest I can run the board with L1 cache disabled.
Some more:
7.2 KiB
150x5; 750MHz; L1D
7.06 KiB
150x3; 450MHz; L1D
We're now somehere in the region of the classic 486DX2-66...
And:
7.52 KiB
66x3; 200MHz; ICD; BPD
The above is the slowest (~ 22pts) I can run this board with L1 cache still enabled. I used both ICD and BPD with the slowest multi (3) and FSB (66Mhz).
More to follow... (I can only upload 5 pics per post...)
Reply 12 of 44, by j^aws
Continuing from above:
7.17 KiB
100x5; 500MHz; L1D
5.91 KiB
100x5; 500MHz; L1D; BPD
Around these speeds, it is taking too long to run the memory profile tests in Speedsys, so I've skipped most of them. The speeds below 30pts can be achieved in multiple ways because there are many parameters that can be adjusted...
5.94 KiB
100x3; 300MHz; L1D
5.93 KiB
75X6; 450MHz; L1D
5.95 KiB
66X16; 1066MHz; L1D
More to follow...
Reply 13 of 44, by j^aws
Continued from above:
5.93 KiB
66x6; 400MHz; L1D
5.92 KiB
66x4.5; 300MHz; L1D
5.9 KiB
66X3.5; 233MHz; L1D
5.93 KiB
66X3; 200MHz; L1D
5.93 KiB
66x3; 200MHz; L1D; BPD
More to follow...
Reply 14 of 44, by j^aws
Continued...
7.28 KiB
66x3; 200MHz; L1D; BPD; Slowest BIOS timings
This is the slowest I can achieve in Speedsys - 9.46pts, using the slowest timings in the BIOS. Around these speeds, the accuracy reported by Speedsys can have discrepancies. It is reporting a fast 386DX currently. I normally cross-reference other benchmarks to get an idea on where the CPU is at. For example, Topbench is reporting around a 386SX-25 and so is NSSI. However, Norton Sysinfo 6 is around 386SX-16 levels or slower.
If the board had a 50MHz FSB option, it should hit around a fast 286.
@Clueless1: I'll try to get those other benchmarks for you later...
Time for a break now, and to decide what VGA card I should use - can't decide on whether this C&T F69000 is worth keeping. Any interests in other benches, feel free to request.
Reply 15 of 44, by clueless1
Quite an amazing processor. 😀
Reply 16 of 44, by j^aws
As requested by clueless1:
CPU: VIA C3 Ezra-T, 440BX chipset
VGA: C&T F69000
Speed: 1000Mhz ; 133x7.5; L1 enabled
Speedsys = 528.5
3D Bench = 325.4
PC Player = 99.1
Doom: Gametics = 2134; Realtics = 854; FPS = 87.45
Speed: 1000Mhz ; 133x7.5; L1 disabled
Speedsys = 29.9
3D Bench = 32.1
PC Player = 10
Doom: Gametics = 2134; Realtics = 5082; FPS = 14.70
Speed: 1200Mhz ; 150x8; L1 enabled
Speedsys = 632.85
3D Bench = 343.1
PC Player = 110.9
Doom: Gametics = 2134; Realtics = 763; FPS = 97.89
Speed: 1200Mhz ; 150x8; L1 disabled
Speedsys = 34.07
3D Bench = 36.6
PC Player = 11.5
Doom: Gametics = 2134; Realtics = 4447; FPS = 16.80
Speed: 200Mhz ; 66x3; L1 enabled
Speedsys = 105.70
3D Bench = 132.0
PC Player = 31.1
Doom: Gametics = 2134; Realtics = 2073; FPS = 36.02
Speed: 200Mhz ; 66x3; L1 disabled
Speedsys = 11.93
3D Bench = 13.0
PC Player = 4
Doom: Gametics = 2134; Realtics = 12896; FPS = 5.79
As mentioned earlier, Ezra-T doesn't have a Level 2 Cache hierarchy, so no benches for it. The VGA onboard isn't the fastest, but it does seem compatible, and with decent image quality...
I'll upload the above benches into the spreadsheet shortly.
Reply 17 of 44, by clueless1
Thanks, j^aws! Quite an impressive chip.
Reply 18 of 44, by Tetrium
I'm wondering who here has ordered a VIA C3 because of this 😁
Reply 19 of 44, by Tertz
Would be more comfortable to see one table with all settings-results from the fastest to the slowest for Ezra-T 1000. As you also have Nehemiah 1200, its results are similarly interesting.
For video card you may use a standard S3 Trio64V+ or VirgeDX (72 MHz) as most people would use something close by the performance in case of Win9x-DOS build. It's possible also to run 2nd series of tests with ISA, as this may add to slowdown, while there were fast and slow ISA cards to choose from.
Tests that may be done. CPU: Speedsys, Speedtst (with /L), Snooper - they work on wide range of CPUs. Gaming: doom, quake, 3dbench, pcpbench - what Phil used for database. FPU tests for stock and overclocked states: Super Pi Mod. Any other which have a base for comparision.
and ICD slowdown option seems as not available with this
Yamaha YMF7x4 Guide
