First post, by Darkman
- Oldbie
Ive decided to build a Socket 939 system and have decided to go with an Opteron 148 as opposed to an Athlon64 FX. The board is an Abit AV8 (latest BIOS) and the CPU is recognised , however there is one issue regarding tempratures.
the system is giving me 2 different readings for the temperature of the CPU in the BIOS and in Everest shows a temperature of 60C or more under load , while in HWMonitor the temperature is a much lower 40C.
the CPU is using the stock AMD heatsink/fan , and the thermal paste Im using is Arctic Silver Ceramique. Furthermore the board is currently sitting outside of the case (still waiting for that one in the post), so there isnt a problem of airflow.
here is a screenshot of both Everest and HWMonitor giving me different readings (this was after installing and running Quake4 for about 15-20 minutes)
So what is happening with these temp readings? 60 seems pretty high if its really that temperature (the heatsink doesn't feel particularly warm either)
Thanks in advance
