DOSBOX fork with better FM synthesis?
General information and assistance with DOSBox.
Postby Stiletto » 2016-8-01 @ 17:00
A passing comment from R. Belmont of MAMEdev team:
"also, (at least) one of the dosbox fork(s) apparently has FM that blows MAME's away ... but I forget where I saw it"
anyone? :)
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Re: DOSBOX fork with better FM synthesis?
Postby leileilol » 2016-8-01 @ 22:02
probably oplemu compat in mainline dosbox. The only recent more accurate FM emulator i know of is khokh2001's nuked opl3 fm and that hasn't been backported to dosbox AFAIK.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby KainXVIII » 2016-8-01 @ 22:23
leileilol wrote:The only recent more accurate FM emulator i know of is khokh2001's nuked opl3 fm and that hasn't been backported to dosbox AFAIK.
Interesting, does it have standalone installer (like Munt) or you need somehow compile it yourself?
User avatar
KainXVIII
Postby keenmaster486 » 2016-8-02 @ 03:15
I've found "fast" OPL3 emulation to sound more like the original, that is, when you set all the frequencies to 49716 Hz.
I flermmed the plootash just like you asked.
http://classictechnology.herokuapp.com
Vintage desktops: Pentium/MMX 200 (Win95), 286-12 (MS-DOS 5.0)
Vintage laptops: IBM Thinkpad A20m, IBM Thinkpad 560X, IBM Thinkpad 365CD
User avatar
keenmaster486
Postby leileilol » 2016-8-02 @ 04:05
fast sounding better than compat is placebo effect at that point. It won't sound better in CyberSphere.
User avatar
leileilol
Postby Stretch » 2016-8-12 @ 12:20
PC1: Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Soundblaster 32
PC2: Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2048 MB - Geforce FX5700 - Vortex 2 - SBLive SB0100 - YMF744
Stretch
Postby Stiletto » 2016-8-12 @ 16:11
Stretch wrote:Must be this one
viewtopic.php?f=41&t=49327
R. Belmont made his comment _before_ that thread was posted. But that poster had made his emulator before he made his DOSBox patch. So I'm not really sure.
Stiletto
User avatar
Stiletto
Postby James-F » 2016-8-12 @ 16:24
It sounds the same to me.
Maybe nukeykt (khokh2001) the author of Nuked OPL could chime in and explain the difference to Dosbox OPL?
User avatar
James-F
Postby James-F » 2016-8-13 @ 04:53
They sound absolutely identical to me.
I'm not an expert but I've read that the OPL3 has only 8 basic waveforms to emulate, and I think dosbox does an excellent job.
How more accurate simple sinewave sawtooth or squarewave can be ??
Anyway, here are a quick comparison between Nuked OPL and Dosbox OPL:
Nuked 2.mp3
(842.04 KiB) Downloaded 138 times
Nuked 1.mp3
(844.08 KiB) Downloaded 132 times
Dosbox 2.mp3
(838.77 KiB) Downloaded 113 times
Dosbox 1.mp3
(840.81 KiB) Downloaded 131 times
User avatar
James-F
Postby nukeykt » 2016-8-15 @ 08:53
Here's comparison between four opl3 emulators: Nuked OPL3, DOSBox fast OPL3, DOSBox compat OPL3, MAME/MESS OPL3. Unfortunately i can't record real OPL3. So I also uploaded original midi file: https://www.dropbox.com/s/4b8bir5gyy6q1 ... 0.MID?dl=0
lion10-mameopl3.mp3
MAME/MESS OPL3
(2.13 MiB) Downloaded 122 times
lion10-dbcompat.mp3
DOSBox compat OPL3
(2.11 MiB) Downloaded 113 times
lion10-dbfast.mp3
DOSBox default,fast OPL3
(2.18 MiB) Downloaded 109 times
lion10-nukedopl3.mp3
Nuked OPL3
(2.13 MiB) Downloaded 138 times
nukeykt
Postby James-F » 2016-8-15 @ 14:16
Interesting.
Dosbox-Fast sounds closer to Nuked-OPL, but has lower pitch "kick drum".
Dosbox-Compat is muddy and distorted.... are you sure you did not mix the names of Compat and Fast?
MAME is less distorted than Dosbox-Compat but still not as clean as Dosbox-Fast or Nuked.
What game is it from so I can record a real OPL-SA3 for comparison.
User avatar
James-F
Postby nukeykt » 2016-8-15 @ 14:28
No. This is case where compat loses to fast emu. This music is from Lion King port to Windows 95. BTW I just recorded sample from ymf718 myself.
lion10-ymf718.mp3
YMF718 OPL3.
(2.11 MiB) Downloaded 105 times
nukeykt
Postby James-F » 2016-8-15 @ 14:40
A horrible recording (there is some strange effect), but pitch-wise Nuked sounds the closest.
Yet, Dosbox-Fast is not bad at all.
Any examples where dosbox-Fast is less accurate than Compat?
I've been under the impression that Compat is MORE accurate than Fast... where clearly it is not so in this example.
User avatar
James-F
Postby Scali » 2016-8-15 @ 14:48
James-F wrote:A horrible recording
Using mp3 is not a good idea for this. Regular WAV or FLAC would be better for comparison.
Now you can't tell whether the distortion is caused by inaccurate emulation, or if it is aliasing from the mp3 codec used.
Scali
Postby James-F » 2016-8-15 @ 14:53
No no, there is something wrong with the recording itself of the YMF718, not with the WAV to MP3 conversion.
The MP3s are 320kbps, I doubt anyone could hear the difference (another topic altogether).
Ignoring the bad recording and concentrating on the Pitch and Sound accuracy, Nuked OPL is a perfect match.
Dosbox-Compat is absolutely horrendous here, and I thought is was the most accurate... keenmaster486 was right.
EDIT:
I just noticed there is a MID file of the song.
I will record my YMF719 and be back.
User avatar
James-F
Postby nukeykt » 2016-8-15 @ 15:15
James-F wrote:Any examples where dosbox-Fast is less accurate than Compat?
Yes. Now i'm recording song where DOSBox fast and MAME sound inaccurate, but DOSBox compat and Nuked OPL are good.
nukeykt
Postby nukeykt » 2016-8-15 @ 15:28
Ok. I've recorded. YMF718 applies "3D" effect to sound. But i don't know how to disable it.
This song is from Disney's Aladdin port to Windows.
arrock1-ymf718.mp3
YMF718 OPL3
(2.81 MiB) Downloaded 112 times
arrock1-nukedopl3.mp3
Nuked OPL3
(2.85 MiB) Downloaded 124 times
arrock1-mameopl3.mp3
MAME/MESS OPL3
(2.85 MiB) Downloaded 84 times
arrock1-dbfastopl3.mp3
DOSBox default, fast OPL3
(2.84 MiB) Downloaded 90 times
arrock1-dbcompatopl3.mp3
DOSBox compat OPL3
(2.88 MiB) Downloaded 87 times
nukeykt
Postby James-F » 2016-8-15 @ 15:35
nukeykt wrote:Ok. I've recorded. YMF718 applies "3D" effect to sound. But i don't know how to disable it.
Open windows Volume Control and simply mute "3D WIDE", at least it is how it's on Windows 98.
I you don't see it, enable it in Options->Preference.
If you can please replace your YMF718 recordings without "3D WIDE".
I attached the first Lion track from YMF719.
Lion YMF719.mp3
V3
(2.13 MiB) Downloaded 81 times
User avatar
James-F
Postby James-F » 2016-8-15 @ 15:42
I can't find a time where they sound different.
What second?
User avatar
James-F
Postby nukeykt » 2016-8-15 @ 15:46
James-F wrote:I can't find a time where they sound different.
Listen to Saw wave, which plays all time. In DOSBox fast and MAME it is less modulated.
nukeykt
Next
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 0 guests
