DOSBOX fork with better FM synthesis?
First post, by Stiletto
A passing comment from R. Belmont of MAMEdev team:
"also, (at least) one of the dosbox fork(s) apparently has FM that blows MAME's away ... but I forget where I saw it"
anyone? 😀
do the Fandango!" - Queen
Stiletto
Reply 1 of 66, by leileilol
probably oplemu compat in mainline dosbox. The only recent more accurate FM emulator i know of is khokh2001's nuked opl3 fm and that hasn't been backported to dosbox AFAIK.
long live PCem
Reply 2 of 66, by KainXVIII
Interesting, does it have standalone installer (like Munt) or you need somehow compile it yourself?
Reply 3 of 66, by keenmaster486
I've found "fast" OPL3 emulation to sound more like the original, that is, when you set all the frequencies to 49716 Hz.
World's foremost 486 enjoyer.
Reply 6 of 66, by Stiletto
Stretch wrote:
R. Belmont made his comment _before_ that thread was posted. But that poster had made his emulator before he made his DOSBox patch. So I'm not really sure.
Stiletto
Reply 8 of 66, by James-F
They sound absolutely identical to me.
I'm not an expert but I've read that the OPL3 has only 8 basic waveforms to emulate, and I think dosbox does an excellent job.
How more accurate simple sinewave sawtooth or squarewave can be ??
Anyway, here are a quick comparison between Nuked OPL and Dosbox OPL:
    Nuked 2.mp3
    842.04 KiB
    537 downloads
    Nuked 1.mp3
    844.08 KiB
    524 downloads
    Dosbox 2.mp3
    838.77 KiB
    483 downloads
    Dosbox 1.mp3
    840.81 KiB
    535 downloads
Reply 9 of 66, by nukeykt
Here's comparison between four opl3 emulators: Nuked OPL3, DOSBox fast OPL3, DOSBox compat OPL3, MAME/MESS OPL3. Unfortunately i can't record real OPL3. So I also uploaded original midi file: https://www.dropbox.com/s/4b8bir5gyy6q1aq/LION10.MID?dl=0
    lion10-mameopl3.mp3
    2.13 MiB
    504 downloads
    MAME/MESS OPL3
    lion10-dbcompat.mp3
    2.11 MiB
    511 downloads
    DOSBox compat OPL3
    lion10-dbfast.mp3
    2.18 MiB
    484 downloads
    DOSBox default,fast OPL3
    lion10-nukedopl3.mp3
    2.13 MiB
    518 downloads
    Nuked OPL3
Reply 10 of 66, by James-F
Interesting.
Dosbox-Fast sounds closer to Nuked-OPL, but has lower pitch "kick drum".
Dosbox-Compat is muddy and distorted.... are you sure you did not mix the names of Compat and Fast?
MAME is less distorted than Dosbox-Compat but still not as clean as Dosbox-Fast or Nuked.
What game is it from so I can record a real OPL-SA3 for comparison.
Reply 11 of 66, by nukeykt
No. This is case where compat loses to fast emu. This music is from Lion King port to Windows 95. BTW I just recorded sample from ymf718 myself.
    lion10-ymf718.mp3
    2.11 MiB
    492 downloads
    YMF718 OPL3.
Reply 12 of 66, by James-F
A horrible recording (there is some strange effect), but pitch-wise Nuked sounds the closest.
Yet, Dosbox-Fast is not bad at all.
Any examples where dosbox-Fast is less accurate than Compat?
I've been under the impression that Compat is MORE accurate than Fast... where clearly it is not so in this example.
Reply 13 of 66, by Scali
Using mp3 is not a good idea for this. Regular WAV or FLAC would be better for comparison.
Now you can't tell whether the distortion is caused by inaccurate emulation, or if it is aliasing from the mp3 codec used.
Reply 14 of 66, by James-F
No no, there is something wrong with the recording itself of the YMF718, not with the WAV to MP3 conversion.
The MP3s are 320kbps, I doubt anyone could hear the difference (another topic altogether).
Ignoring the bad recording and concentrating on the Pitch and Sound accuracy, Nuked OPL is a perfect match.
Dosbox-Compat is absolutely horrendous here, and I thought is was the most accurate... keenmaster486 was right.
EDIT:
I just noticed there is a MID file of the song.
I will record my YMF719 and be back.
Reply 15 of 66, by nukeykt
Yes. Now i'm recording song where DOSBox fast and MAME sound inaccurate, but DOSBox compat and Nuked OPL are good.
Reply 16 of 66, by nukeykt
Ok. I've recorded. YMF718 applies "3D" effect to sound. But i don't know how to disable it.
This song is from Disney's Aladdin port to Windows.
    arrock1-ymf718.mp3
    2.81 MiB
    505 downloads
    YMF718 OPL3
    arrock1-nukedopl3.mp3
    2.85 MiB
    511 downloads
    Nuked OPL3
    arrock1-mameopl3.mp3
    2.85 MiB
    467 downloads
    MAME/MESS OPL3
    arrock1-dbfastopl3.mp3
    2.84 MiB
    470 downloads
    DOSBox default, fast OPL3
    arrock1-dbcompatopl3.mp3
    2.88 MiB
    453 downloads
    DOSBox compat OPL3
Reply 17 of 66, by James-F
Open windows Volume Control and simply mute "3D WIDE", at least it is how it's on Windows 98.
I you don't see it, enable it in Options->Preference.
If you can please replace your YMF718 recordings without "3D WIDE".
I attached the first Lion track from YMF719.
    Lion YMF719.mp3
    2.13 MiB
    446 downloads
    V3
