Reply 4520 of 31866, by m1919
- Member
wrote:Are you running it at a 100MHz FSB? Or on 112MHz?
wrote:wrote:Toying around with the XG-DLS rig, running into issue with a fairly consistent BSOD after booting into Windows. Currently runnin […]
Toying around with the XG-DLS rig, running into issue with a fairly consistent BSOD after booting into Windows. Currently running XP. Seems to be some kind of hardware conflict as the bluescreen is referencing IRQL_NOT_LESS_OR_EQUAL error.
Only thing I can think of that may be causing the issue is I currently don't have any PS2 keyboard or mice so the machine may be wigging out due to USB keyboard and mouse combo. I did a quick test this morning for about 10 minutes of runtime in windows with just the keyboard plugged in and did not seem to get the bluescreen, which usually happens pretty quick after booting into windows.
Anyone else encounter this on old boards like this?
Does not appear to be hardware failure of any other kind as all other hardware in this setup worked on my other XG-DLS board. I ran through Windows XP install again but the process gets stuck when starting windows after setup file transfer is done. Also ran a few memtest86 passes and got a hardware related interrupt failure on CPU0 eventually, no actual memory error. I know these procs will do 112Mhz FSB so I'm assuming it's the USB devices as most likely there were very few USB keyboards/mice around back in the late 90s early 2000s.
Well, tested the XG-DLS with just my cheapo Microsoft USB laser mouse plugged in. Did not get a bluescreen with the machine just sitting idle for 3-4 hours, but when attempting to install 3dmark01, the machine just rebooted spontaneously, no bluescreen. Then during POST it got stuck in loop testing memory.
Looks like either I have some bad sticks which I can swap for another set or I can try cleaning the contacts and re-seating them... This machine is getting frustrating to deal with.
I can drop down to 112Mhz FSB and retest. Maybe this board does not like 112Mhz, I know the procs are good for it though as I was running these at 784Mhz on the other board for months with no problem.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
