First post, by PhilsComputerLab
To calibrate a video capture card to the output of 3D only cards, like a 3dfx Voodoo or Voodoo 2, I'm after a way to display Elinda's calibration images in D3D and/or OpenGL and/or Glide.
Sounds simple, but I don't know of such a tool.
Another idea is swapping out an image file of a game maybe, that uses plain image files as a background or something like that.
YouTube, Facebook, Website
Reply 2 of 45, by PhilsComputerLab
yawetaG wrote:
Wouldn't the SDK's for D3D/OpenGL/Glide include such tools?
I have no idea. I really need something that is ready to go, and need it rather soon 😊
Reply 3 of 45, by Scali
I don't think there are tools for that. They'd need to be developed.
Not too difficult (just two triangles covering the whole screen with a triangle covering it, taking care of the subpixel/subtexel positioning to make sure you get a proper 1:1 pixel:texel mapping), but someone has to do it.
I have some Direct3D 1.0 code that someone could use if they are interested. I have various other projects going on right now, so I don't know if or when I'd be able to make such a tool myself.
Reply 5 of 45, by Scali
leileilol wrote:
The 256x256 splitting of the image has to be done too
Oh yea, good point. I forgot that only 'modern' cards have the luxury of non-pow2 texturing 😀
Reply 6 of 45, by spiroyster
Can you post the image? I can possibly whip up a GL 1.2 (win9x) program to display said image either later or tomorrow (probably tomorrow). twould be a Blast from the past!
Easiest thing to do is convert to PPM (just post the image, I can convert it), since this is text based and can be hardcoded into the program. There is no jpg, png, tga etc support out of the box with GL. So raw uncompressed. Do you just want simple exe to just display the calibration image (maintaining aspect ratio?). If you want full screen, it would require glut (not the end of the world, I just like to keep my code as devoid of 3rd party as possible 😀) as I have never done native windows full screen GL.
And yes, as others have said, best if its dimensions are 2^n (power2 texture), especially if you don't require filtering (only nearest neighbour interpolation) otherwise you may get some artefacts from the texel interpolation. Bilinear or Anisotropic should mitigate this but you might not get detail which is usually required for calibration? Let me know which filtering.
I would be interested to see a Glide equivalence of this code 😀 Can't do D3D for you though I'm afraid.
Reply 7 of 45, by PhilsComputerLab
That would be awesome, thank you!
Images are attached.
    Calibration images.zip
    17.95 KiB
    137 downloads
Reply 9 of 45, by leileilol
It's less about 2D core and more about image quality handled in the 3d core
and probably texture formats too. To get a 24-bit image on a 3dfx Voodoo would probably involve 3x grayscale per component paletted textures additively blended, appropriately vertex color modulated, but there would probably be still precision loss from the blend and the dithering on the texture mapping unit anyway (which in turn, brings us the entire point of this thread's prospect)
What I usually did was make a special menu page for Q3 Team Arena code 😉 It's OpenGL at that point, but there's dozens of wrappers!
Reply 10 of 45, by Scali
mrau wrote:
d3d? isnt ddraw enough?
Good question. I'm not sure if you would be able to get a non-D3D surface on a VooDoo card, and if so, if that surface is lockable, or if you could otherwise blit 2D images to it. Might be possible.
But leileilol raises an interesting point there... because if the textureformats don't support 24-bit rendering, then the quality of rendering an image via textures would be different than just blitting the pixels 1:1.
Reply 11 of 45, by leileilol
There's at least one DirectDraw sample app in the DX6 SDK that can render on the Voodoo2 in 2D at least. Forget which though
EDIT: FSWINDOW.EXE. It renders a bouncing ball on a black background in 2d on the card. as well as a typical Windows dialog box.
13.33 KiB
FSWINDOW.EXE on PCem's Voodoo2 emulation
Reply 13 of 45, by spiroyster
Hello, apologies for the delay. xmas occurred o.0
So, that was an interesting experience 😲 , so used to C++14 that I forget how much the language has evolved and there are sooo many trivia things these days that I take for granted. Can't say I miss much of the old days, coding-wise though.
In all my excitement I overlooked one rather key factor, I don't have access to my VS6.0 (Aspen) environment since we have recently moved house and I haven't got around to setting up my retro rig yet. Also, its a P3 SGI workstation, with quite sophisticated GL implementation so I can't test with 'limited' GL hardware (eg. voodoo etc.) 😵 . However the code has no STL, no glut (thanks again Nehe), uses OpenGL 1.1, is Win32 and is (I think) C++98 compliant so hopefully someone else will have access to VS6.0 and can build you a binary (.exe) ??? Anyone ??? since there are feckall dependencies (other than GL and windows).
Sauce:
https://raw.githubusercontent.com/spiroyster/ … aster/ppmgl.cpp
I have included a VS2015 built binary in the repo (ppmgl.exe), but you will need the VC++ Redist for VS2015 which is available for WinXP! but nothing earlier (like 2000, ME, 9x).
It loads PPM Ascii files (P3). I converted your images using gimp:
1) Load in your image to GIMP
2) File->Export As
3) Rename the extension to .ppm
4) Select ASCII from the Export option.
To use:
> ppmgl image.ppm /fullscreen
('/fullscreen' is optional)
Let me know if you get any problems.
Merry Chirstmas and all that jazz 😀
Reply 14 of 45, by PhilsComputerLab
spiroyster wrote:
But nothing earlier (like 2000, ME, 9x).
Oh dear, I guess I should have mentioned that. These old machines don't run XP, mostly DOS and Windows 98 at best.
Reply 15 of 45, by xjas
mrau wrote:
voodoo2 allegedly can display the desktop in XWindows under linux so it must have some facilities
You can absolutely write pixels directly to the voodoo 1 & 2's framebuffer memory, just like a 2D card. I looked into this for a backburner project I was/am working on but haven't gotten around to writing the code that does it yet.
Look at the Linux sstfb driver for inspiration.
Reply 16 of 45, by spiroyster
As in, the vs2015 compiled binary in the repo required vs2015 redist so will not work pre xp, however if you compile that code with vs6.0, it will work on all windows but no dos 😀. Cannot test though, but is written with old syntax, come the new year I will fire up the old beast and can built you an exe for win95. 0.o
Reply 17 of 45, by PhilsComputerLab
Windows 9x would be perfect! Voodoo and Voodoo 2 work great with that version. I'm in no rush, and thank you for helping!
Reply 18 of 45, by DOSfan1994
Voodoo 2 does not do 2D nor have a 2D core.
Reply 19 of 45, by spiroyster
Have updated, included now is a compiled executable which should work. I'm hoping anyway. (win9x)+
https://github.com/spiroyster/ppmgl/raw/master/ppmgl.exe
Also ppm versions of your calibration images can be found ...
