Reply 15380 of 53209, by foey
Anyone have an idea what this card could be? It got it in a ISA bundle, it looks like it's from 2005.
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 15381 of 53209, by agent_x007
meljor wrote:
I cannot find a direct comparison between a bliss 7800gs+ and a x850xt Platinum Edition.
So, if you have both: you got some benchies to do! 🤣
I got a Gainward 7900 GS (20PS/7VS, hard locked).
Here's comparison of it to x850XT PE, and few other cards : LINK
Text is in Polish, but charts are English friendly 😉
Reply 15383 of 53209, by Kamerat
Found a picture of the card, not much details but maybe the category it's listed under gives you a hint.
https://www.aliexpress.com/item/tpb-sa-822101 … 2413016111.html
YouTube channel
Reply 15384 of 53209, by Skalabala
keropi wrote:
@foey
plug it in a pci-e 1x slot and see what windows comes up with. The Spartan IC you photographed does not help since it's a FPGA and can have anything programmed in it
Could be AMR slot?
Reply 15385 of 53209, by meljor
agent_x007 wrote:
I got a Gainward 7900 GS (20PS/7VS, hard locked). Here's comparison of it to x850XT PE, and few other cards : LINK Text is in Po […]
Thank you, looks like the 6800 got some boost with later drivers, compared to old reviews it got closer with x850xt pe. 7900gs is quicker, no doubt. So Artex's 24/8 card should be even faster.
His card is the same as the 7950GT AGP which i have never seen in the wild.
Reply 15386 of 53209, by meljor
It is listed under DVR but when is earch google for pci-e dvr card every single one of them has connectors.
I want to know what it is! 🤣
Reply 15387 of 53209, by elod
As it does not have interfaces it does some kind of processing partially implemented in the FPGA.
Maybe the chip under the heatsink/fan would give us a clue?
Reply 15388 of 53209, by meljor
Just install it in a modern machine and see what windows comes up with. that's what i would do.
Reply 15389 of 53209, by mrau
installing a damaged device is, contrary to what youre being told here, a rather bad idea;
Reply 15390 of 53209, by yawetaG
Maybe a hardware encryption card?
Reply 15391 of 53209, by brostenen
As promised... Some pictures of the SCSI haul. I have only had power on the Lacie box, and it really need an overhaul.
The fan is loud and sounds like it is about to give up. I will try and give it some new oil, and see if it fixes it.
Need to tighten a coupe of screws and clean it up too. Two of the CD-Drives are tray, the Plextor is a caddy one.
Then there are a Tape drive, HP Branded, wich are one of those professional ones. No media sadly, so I can't test it.
Finally there are three controllers, wich one of the ISA ones have horrible bent pins, and there are a cable i needed.
Happy with this little SCSI haul.... Not bad for free stuff. Anyone knows what caddy to look for and is there anyone
here that knows anything about that HP tape drive? (I was thinking in terms of were and how to deploy it)
Splitting this up in two posts, as there are 8 pictures in all. Uhhh... Forgot... There is a terminator too. 😜
(does not come with Arnold included 🤣 )
This is going to be so awesomme, adding a complete SCSI setup onto my Unisys Pw/2 Series-300 80286 machine.
Reply 15392 of 53209, by brostenen
Reply 15393 of 53209, by foey
I've put it in my 2006 AMD-X2 build running Windows XP SP3, It comes up as an "Unknown device" It's not going near my main rig 🤣
Reply 15394 of 53209, by Jade Falcon
Rank BANNED
BANNED
pull the heat sinks off. I'm sure there something under there that would help. Could be a encoder card or something. If you take a look it has a header on the back of the card. Also Try something like PCI-z to see what it is.
Reply 15395 of 53209, by foey
Also as part of the bundle got this 1993 Cirrus Logic 5428 1mb VLB Graphics card. Have absolutely nothing to use this in 🤣
Reply 15396 of 53209, by meljor
foey wrote:
Also as part of the bundle got this 1993 Cirrus Logic 5428 1mb VLB Graphics card. Have absolutely nothing to use this in :lol: […]
We really don't care, we just want to know what the pci-e card is!! 🤣 🤣 🤣 😁 😁
Reply 15397 of 53209, by brostenen
Cool.... VLB's are nice stuff. Those mem chips are giant ones. Exactly like those on my CL isa card.
Reply 15398 of 53209, by foey
OK, so I've taken off the small heatsink at the top which reveals the following chip...
I've also removed the heatsink and fan which reveals this...
Reply 15399 of 53209, by yawetaG
The EFI chip appears to be a video controller chip; see for example this Ebay auction http://www.ebay.com/itm/Konica-Minolta-Bizhub … 1-/271979569052
EFI apparently is an industrial digital imagings manufacturer who make a variety of hard- and software: http://www.efi.com/. Perhaps the card comes out of one of their specialized systems?
