As promised... Some pictures of the SCSI haul. I have only had power on the Lacie box, and it really need an overhaul.
The fan is loud and sounds like it is about to give up. I will try and give it some new oil, and see if it fixes it.
Need to tighten a coupe of screws and clean it up too. Two of the CD-Drives are tray, the Plextor is a caddy one.
Then there are a Tape drive, HP Branded, wich are one of those professional ones. No media sadly, so I can't test it.
Finally there are three controllers, wich one of the ISA ones have horrible bent pins, and there are a cable i needed.
Happy with this little SCSI haul.... Not bad for free stuff. Anyone knows what caddy to look for and is there anyone
here that knows anything about that HP tape drive? (I was thinking in terms of were and how to deploy it)
Splitting this up in two posts, as there are 8 pictures in all. Uhhh... Forgot... There is a terminator too. 😜
(does not come with Arnold included 🤣 )
This is going to be so awesomme, adding a complete SCSI setup onto my Unisys Pw/2 Series-300 80286 machine.
