VIDEO Patch for pixel-perfect scaling (SDL1)
Reply 260 of 733, by marooned_on_mars
Ant_222 wrote:
Nope, I was not going to say that. My own main PC is some twelve years old and has Windows XP on it, and my other PC sports an old Viewsonic LCD with a resoltion of 1024x768.
Ah, that's not what I meant, I meant that for pixel perfect to work, I would need a higher resolution monitor, as some have suggested in this thread, and as you mentioned.
Ant_222 wrote:
I don't know what that munt diff is all about and how it is related to my patch. Do you suggest that I should include it into my patch and maintain it? What about the original author?
No. If you recall, I had problems applying the munt diff after using your patch, so I fixed it to work with your own patch, and I wanted you to add it to the first post of this thread, so it would be visible to others who might need it.
Reply 261 of 733, by Ant_222
The pixel-perfect patch does work even with your relatively small monitor, but it has not enough space to apply aspect-ratio correction and is forced display the image with unity PAR. If you get any aspect correcton with other settings, it is lossy and distorts the image by interpolation, either bilinear or nearest-neighbor.
OK, I will (Edit: done), but you had better notify the maintainer/author of this patch, because further updates may break it again...
Reply 262 of 733, by marooned_on_mars
There are likely many other patches that don't play nice with munt's, so that's why I decided against contacting the author.
Reply 263 of 733, by jfrisby
I posted about this in the request thread months ago and just found the patch -- AMAZING! Works great! Looks perfect!
RIP years of correcting aspect ratios manually in screenshots. A good reason to replay everything 😁
Reply 264 of 733, by KainXVIII
Found another game which works bad without surface-collapse-dbl set to true - Normality, if someone interested. If set to false game screen is much smaller and when you press alt+enter to enter windowed mode dosbox just hangs.
Also Jazz Jackrabbit has strange behavior in windowed mode with pixel-perfect enabled.
Reply 266 of 733, by KainXVIII
Leisure Suit Larry 3 - Sierra logo do not looks round, if aspect ratio set to true
Reply 267 of 733, by KainXVIII
Knight of Xentar crash in windowed mode, here is console log
Reply 268 of 733, by Ant_222
I missed your posts. I will look into these problems.
Reply 269 of 733, by Ant_222
I failed to reproduce the problem. With what config settings did you start the game and what did you do for it to crash? I see three lines reporting different scaling lines in your log screenshot, the last one being wrong.
Reply 270 of 733, by Ant_222
I think it is one of those Amiga-oriented titles, such as Lure of the Temptress, which must be played without aspect-ratio correction, because on Amiga 320 x 200 already gives a unity PAR.
Reply 271 of 733, by Ant_222
Confirmed. The menu and cutscenes are reported as 320 x 200 with an aspect ratio of 1.2 (correct), whereas in-game as 320 x 199 (!) with an aspect ratio of 1.0. The snag is that even vanilla DOSBox reports the 199-pixel height, which I have tested by taking screenshots with the built-in function (CTRL-F6 on Windows). I don't think it is a problem of my patch...
The two remaining problems are very likely caused by errors in the patch, though.
Reply 272 of 733, by KainXVIII
Glad that you back 😎 I'll try to reproduce it too (with DOSBox SVN r4006 ECE (with FLAC) by Yesterplay)
Reply 273 of 733, by Ant_222
Thanks for all the testing you have done, KainXVIII. I shall have time to look into the code at the weekend.
Reply 274 of 733, by KainXVIII
Still same error with latest version of Dosbox SVN in Knights of Xentar
Some dosbox.conf settings that i use
fullscreen=true fulldouble=false fullresolution=desktop windowresolution=original output=surfacepp autolock=true sensitivity=100 […]
fullscreen=true
fulldouble=false
output=surfacepp
autolock=true
sensitivity=100
surfacenp-sharpness=50
surface-collapse-dbl=false
machine=svga_s3
frameskip=0
aspect=true
scaler=none
Reply 275 of 733, by Ant_222
Does it appear right after you launch the game?
Reply 276 of 733, by KainXVIII
Only after i switch to windowed mode (alt+enter)
Reply 277 of 733, by Ant_222
Since I still can't reproduce the error will you please tell me whether you enter the pass code and start the game before switching to windowed mode? Does the error remain with
windowresolution=desktop
Reply 278 of 733, by Ant_222
KainXVIII, I have added some logging to see whence the error comes. Could you please reproduce the problem with the attached build and post again the contents of the log window? It being an incomplete build, make sure not to overwrite your current executable.
Reply 279 of 733, by KainXVIII
Ant_222 wrote:
Since I still can't reproduce the error will you please tell me whether you enter the pass code and start the game before switch […]
Even on very first Megatech title screen games crash if i switch to windowed mode.
UPD - with windowresolution=desktop its not!
Here is log with windowresolution=original
The attachment log.jpg is no longer available
And here is with windowresolution=desktop (maybe it helps)
The attachment log1.jpg is no longer available
