mugen
First post, by DMX
Hallo
I have one problem
I want to start a Mugen DBZ game but an error :
Libaray (built in) message : Can`t change video mode
Error detected
I can`t English god to explain it better
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well mugen runs if you change the video mode in the configuration file of mugen
I recall that you have to select 8 bit and some mode 3 or so ?
but don't bother it's too slow.
Water flows down the stream
Reply 2 of 7, by DMX
I edit bit but it doesn`t run
Reply 3 of 7, by DMX
I change to 320x240 and 8 bit now its run but it is all black
I think its run very slowly[/img]
Reply 4 of 7, by DMX
IT runs ehuuuu but very slowly what can I do that it would be faster
Reply 5 of 7, by eL_PuSHeR
use CTRL-F11 and CTRL-F12 to change cpu cycles.
Use some frameskipping > 1
Use dynamic core
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
which part of the it's too slow don't bother didn't you get ?
the conversion of 16->8 bit by the game is slow. and the game itself is demanding.
So unless you have 10 GHz machine I don't expect it to be playable.
Oneday we have native 16 bit support. Then it might be an idea to try it again.
Reply 7 of 7, by DMX
for real
