Windows XP in PCem?
First post, by Sandi1987
Windows XP works fine in PCem but sound not working. I can't find Sound Blaster 16/AWE32 driver for XP.
Reply 1 of 7, by Sammy
I think you have to install it manually via Hardware Wizard, cause XP does not detect ISA cards.
Reply 2 of 7, by leileilol
XP should be able to detect it and use it.
Reply 3 of 7, by Sandi1987
But there is no driver for XP only for NT 4.0. In Windows 2000 sound works normally.
http://www.soundcard-drivers.com/companies/967.htm
Reply 4 of 7, by leileilol
IT COMES WITH ONE
Reply 5 of 7, by Jo22
Windows XP does support SB16, MPU-401 and Gameports..
And ISA PnP. Legacy ISA devices may or may not work. Its device probing feature isn't as sophisticated as Win9x's, I 'd say.
So for non-PnP cards, it might be necessary to configure the resources manually. Anyway, at least a SB16 PnP does work in XP.
Windows XP ISA Non-PnP Adapters
SB16 ISA
Reply 6 of 7, by Sandi1987
leileilol wrote:
IT COMES WITH ONE
I don't have sound after installation. Which version of XP do you have? SP2 or SP3? Did you manual install Sound driver? On Creative website there is NT 4.0 the newest SB16/AWE32 driver.
http://support.creative.com/Products/ProductD … ET=CategoryID:1
Reply 7 of 7, by Jo22
Okay, so I installed a localized copy of Windows XP Pro x86 w/ SP2..
PCem's SB16 card wasn't detected during setup, but afterwards I managed to install the driver manually.
- It was the same one which leileilol mentioned earlier in this thread.
After this, I entered control panel again and made the mixer icon visible. And that's it!
I wasn't required to change any resouces (IRQ/DMA/Port).
For testing purposes, I played onestop.mid and a few wave files using Mplayer2.
