Old games that are better on a Mac?
Emulation of old Macintoshes, Mac hardware, or Mac peripherals.
Postby vogamer » 2017-8-21 @ 07:57
Hi, I apologize if there are other threads on this, however I was wondering which old games are better on a Mac?
I'm particularly fond of FMV games, thanks. =)
vogamer
Re: Old games that are better on a Mac?
Postby olddos25 » 2017-8-23 @ 01:34
I don't have much experience with Macintosh games, but I think that Lemmings and Oh No! More Lemmings beat by far their DOS counterparts because the music is closer to the Amiga version (which is the original by the way) and also the graphics. I can also say the same thing about Arkanoid. I mean, it has no color, but the music and sound effects are better than it's DOS counterpart and it includes the Continue feature present in the Arcade that the DOS version does not have. A pity that its secuel wasn't converted to the Mac.
EDIT:My 100th post! YAY!
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Postby DonutKing » 2017-8-23 @ 05:23
Return to Zork on Mac is a higher resolution than the DOS version so looks a lot better.
However the DOS version's music is far superior especially if you have an MT32 or compatible Roland device.
User avatar
DonutKing
Postby dr.zeissler » 2017-8-23 @ 08:12
For me it's DARK FORCES because the mac version has HIRES support 640x and therefore looks much better.
Btw. if you have a mac-midi-man you can also hook up a mt-32 to your mac :)
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby chinny22 » 2017-8-24 @ 13:14
Just got a Mac G4 as want to try this out as well.
I know Wolf3d has different weapons which interests me
User avatar
chinny22
Postby dr.zeissler » 2017-8-24 @ 17:20
Wolf3D is also HIRES.
dr.zeissler
Postby filipetolhuizen » 2017-9-03 @ 23:14
Macintosh Wolf3d is a completely different version than DOS'. There are no patrolling enemies and they're always facing forward, textures are 128x128 instead of 64x64, it can run up to 640x480 resolution, sounds and music are completely different and there are additional levels plus 2 additional weapons.
Macintosh Prince of Persia 1 is completely remastered, uses some PoP 2 sprites and runs in 640x400.
Macintosh Alone in the Dark CD versions run in 640x400 and have remastered sceneries for that resolution.
Everything else just runs on higher res. and has different or additional music/sounds.
User avatar
filipetolhuizen
Return to Macintosh Emulation
Who is online
Users browsing this forum: No registered users and 0 guests
