VOGONS Driver Library
Re: VOGONS Driver Library
Postby SquallStrife » 2017-8-28 @ 08:30
My apologies for the short service interruption right now, my automatic payment got ballsed up. :-/
All is well now.
[retro swim] | Link | Release Thread
Follow me on Twitter: https://twitter.com/RetroSwimAU
User avatar
SquallStrife
Postby SquallStrife » 2017-8-28 @ 08:36
Stiletto wrote:"File Size Added Category" headers.... Squall, you think these could be clickable to sort up/down, in every category?
It's on the list. :)
User avatar
SquallStrife
Postby appiah4 » 2017-8-28 @ 08:40
Could I please have an account?
I have drivers I would like to contribute.
A500:Rev6|512K+RTC|ACA500+|HxC/df1|C1084S
1994:PCI597-1|P133|32MB|Trio64|ES1868/S2
1997:S1573S|K6-2/400|64MB|M220|V2-SLI|CT4500/32M
2000:GA-BX2000|P3-700E|256MB|GF2GTS|MX300
DELL:GX110LP|PIII1000|512MB|G450|ES1938S/X3M
User avatar
appiah4
Postby gerwin » 2017-9-06 @ 16:19
SquallStrife
It is not really important, but the text line-height is not entirely proper. Text can overlap the text below it. It has always been that way. I think if you just remove line-height styles it should correct itself. Using Firefox here.
User avatar
gerwin
Postby Paralel » 2017-9-09 @ 06:59
SiliconSoft SoundJr. Windows 3.1/95 Driver & Test Program
Drivers provided by the developer for the SoundJr. parallel port sound hardware for Windows 3.1/95, as well as a test program for determining if the hardware is installed and functioning correctly
SoundJr.zip
(569.05 KiB) Downloaded 15 times
Paralel
Postby 33oldnew » 2017-9-16 @ 13:12
Hi
1. SOUND UTILITY for COVOX - Package used to adapt the games and other software to work with analog-to-digital COVOX. Allows multiple programs to play a sound using the COVOX.
2. Window Sound Driver for COVOX on LPT1
Use with care, preferably on the copies
The description is in the Polish language, but that's not a problem to use the translator.
Covox-18P.zip
From 90's years
(23.28 KiB) Downloaded 16 times
33oldnew
Postby xjas » 2017-9-17 @ 00:50
Hey Squall,
I PMed you a while ago - could I get upload access to Vogonsdrivers? I have some sound card drivers (ATI Stereo F/X CD, rescued off my own floppies, currently not extant on the internet(!)) and a few other things (VR stuff, "lost" video utility for the original Asus eeePC models, etc.) I'd like to share.
On that note, all the early beta drivers that support the Oculus Rift DK1 have been wiped off Oculus' website (as I feared would happen!) I have my own archive of a lot of these drivers, exactly as downloaded from Oculus (installer untouched.) Should they go up on Vogonsdrivers? The DK1 isn't compatible with anything they currently host on their website, so if you're trying to run one you need these.
User avatar
xjas
Postby Drill_Sergeant_CH » 2017-9-26 @ 20:17
Hey Guys, hi Squall. Need access for driver-cd upload:
I purchased on Ebay a NEW Microsoft SideWinder ForceFeedback2 Joystick with original packaging (incl. 2 CD-Roms with drivers!). I would like to upload those two CD-Roms (ISO-Files) for the vogons-library.
http://imageshack.com/a/img922/89/aDGgRW.jpg
*** UPDATE: ***
Link for Download: https://drive.google.com/open?id=0B3X30 ... 3NJaUlsbWc
so long
Drill_Sergeant_CH
User avatar
Drill_Sergeant_CH
Postby Drill_Sergeant_CH » 2017-10-04 @ 18:05
#push
User avatar
Drill_Sergeant_CH
Postby Stiletto » 2017-10-04 @ 18:21
Drill_Sergeant_CH wrote:#push
Send SquallStrife a PM, he'd the only person who can give you access.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby Anapan » 2017-10-14 @ 21:54
I just received a Makopad PC (SV-234) in the mail - it's even better than I'd read about - Here's the 95/98 driver and an image:
http://anapan.525lines.moe/sv234.exe
I had to get the driver from Archive.org - I found a directory listing where most Interact accessories' drivers can be downloaded:
https://web.archive.org/web/*/http://ww ... /dlfiles/*
The driver reports it as Interact PC PowerPad Pro 6-button, tho the driver seems to be different from the one already archived (it is the same driver by file-size that came on the disk which had bit-rotted).
User avatar
Anapan
Postby appiah4 » 2017-10-19 @ 10:42
I've come to be in posession of an AWE64 Value Installation CD. I know the Gold CD is on Vogonsdrivers (and actually works with the Value card) but if anyone would want me to upload it somewhere let me know.
EDIT: You can download it here: https://drive.google.com/open?id=0BzmT2 ... VBtdlZyODA
And I wish Squallfire would give me an account :( He doesn't read his messages on Vogons it seems..
User avatar
appiah4
Postby Solarstrike » 2017-10-28 @ 16:51
New guy here, but page seems to be down.
Solarstrike
Postby Cga.8086 » 2017-10-30 @ 03:11
yea dns problem, hopefully vogondrivers will be back
Cga.8086
Postby SquallStrife » 2017-11-01 @ 01:30
Yep, an update broke nginx. All good now! :)
User avatar
SquallStrife
Postby firage » 2017-11-06 @ 23:38
The final DOS software releases for a classic Thrustmaster joystick lineup.
F22_209.zip
Thrustmaster F-22 Pro software v1.09 with the v2.09 RT200 update.
(1.38 MiB) Downloaded 6 times
FLCS_518.zip
Thrustmaster F-16 FLCS software v4.00 with the v5.18 RT200 update. (If the FLCS is used together with the TQS, use the TQS software instead.)
(863.68 KiB) Downloaded 8 times
TQS_518.zip
Thrustmaster F-16 TQS software v4.00 with the v5.18 RT200 update. (If the TQS is used together with the F-22 Pro, use the F-22 software instead.)
(870.66 KiB) Downloaded 6 times
WCS2_813.zip
Thrustmaster WCS Mark II software v8.10 with the v8.13 RT200 update. (If the WCS is used together with the FLCS or F-22 Pro, use their software instead.)
(777.77 KiB) Downloaded 7 times
User avatar
firage
Postby FluffyBunnyFeet » 2017-11-07 @ 16:09
User avatar
FluffyBunnyFeet
Postby Drill_Sergeant_CH » 2017-11-09 @ 21:32
updated my Download-Link (see a few posts above) for MS Sidewinder FF2 Joystick Driver CD's. So please add them to the vogons library.
Cheers
User avatar
Drill_Sergeant_CH
Postby blurks » 2017-11-23 @ 10:06
I uploaded the driver files for the VideoLogic DVD-Player (MPEG2 decoder card for PCI bus).
This includes the drivers, the setup and the readme files from the attached disc but DOES NOT include the DVD Player application as I am not aware of its current copyright status.
http://www60.zippyshare.com/v/6I4wWmrM/file.html
User avatar
blurks
Postby Murugan » 2017-11-28 @ 12:30
Is the library down?
My retrocollection: Commodore 486-33C, Pentium MMX-233, CD32 boxed,Atari 1040STE boxed, Atari 2600JR boxed, Atari 7800 boxed, NES boxed, Amstrad GX4000 boxed, Spectrum Vega boxed :sweatdrop:
User avatar
Murugan
PreviousNext
Who is online
Users browsing this forum: Alexa [Bot], blurks, dionb, istellabot [Bot], KCompRoom2000, MERCURY127, yawetaG and 6 guests
