Intel Marl Socket 7 ATX Restoration
Showcase your Retro PC / Build logs.
Postby Formulator » 2017-10-20 @ 01:29
Restoration of an Intel Advanced/ML (Marl)
Socket 7 ATX/P133/256KB L2
82430HX
Aug-1996
Found in barn on countryside, quite filthy.
Rather simple beige box.
Found stripped of all parts save the processor. Add 32MB EDO, Fireball ST, and the rest.
User avatar
Formulator
Re: Intel Marl Socket 7 ATX Restoration
Postby Anonymous Coward » 2017-10-20 @ 08:04
Nice Inwin. This is what a proper system from the mid 90s should look like...with period correct drives and all.
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby Munx » 2017-10-20 @ 11:24
Great find!
I have the same board and it's really nice to work with - great design for cable management and proper ATX formfactor.
The only couple of issues I ran into were a 200MHz CPU limit and and it didnt't want to post with a K5 in it. Though Im sure that can be adressed with a bios update.
My builds!
The Underdog - The budget K6
User avatar
Munx
Postby Andy1979 » 2017-10-23 @ 12:00
Looks great - have also just built a system with one of these boards. Latest BIOS update is worth installing as it enables booting from CD and fixed some issues I was having with Windows 95 detecting both IDE channels properly.
Think they are limited to non-MMX Intel CPUs (or the MMX overdrive) which isn't surprising for an Intel-made board. Couldn't get mine to run with a 6x86 PR166+.
My Retro systems:
1. AMD 386SX-40, 4mb RAM, AVGA1, DOS 6.2
2. Pentium 133, 48mb RAM, Matrox Millennium 2mb, 3DFX Voodoo 4mb, DOS6.22 / Win95
3. Pentium III 650 (to be constructed)
4. Core2Duo E6600 (to be constructed)
User avatar
Andy1979
Postby chinny22 » 2017-10-27 @ 14:10
nice work, that empty spot for a case badge would annoy me, but was quite common back then
User avatar
chinny22
Postby NJRoadfan » 2017-10-29 @ 15:56
That board might be Intel's first ATX form factor board. It dates to late 1996!
NJRoadfan
Postby Formulator » 2017-10-29 @ 17:13
chinny22 wrote:nice work, that empty spot for a case badge would annoy me, but was quite common back then
Good point, perhaps I could duplicate this badge from another system, as it is my favorite:
User avatar
Formulator
Postby probnot » 2017-10-29 @ 22:18
That badge looks like it's from the 1950's. Like if you got grandma to knit a case badge. I love it.
User avatar
probnot
Postby karpmmx » 2018-11-09 @ 22:20
I know this is an old topic, but does anyone here have Any detailed specs on the Marl board? I just picked up an old TriGem PC with this board, and can't find any information on it, beyond the chipset and processors supported. TriGem is long since defunct.
karpmmx
Postby detritus olentus » 2018-11-15 @ 22:12
Chanced upon this thread and really liked the long-ago-mentioned case badge so I played around in Gimp and MS Paint with my amateur skills. I'm also colorblind so any shade changes I blame on that.
Computer Badge retouch.jpg (85.39 KiB) Viewed 555 times
https://drive.google.com/open?id=11NaRx ... u2rbaWYBRG
https://archive.org/details/@detritus_olentus
Where are my other retro New Jersey Folk?
User avatar
detritus olentus
Postby Formulator » 2018-11-17 @ 01:02
karpmmx wrote:I know this is an old topic, but does anyone here have Any detailed specs on the Marl board? I just picked up an old TriGem PC with this board, and can't find any information on it, beyond the chipset and processors supported. TriGem is long since defunct.
Here are the specs:
http://www.bcmcom.com/tech/sq598/28180602.pdf
Also, nice work cleaning up that case badge image.
User avatar
Formulator
Postby Windows9566 » 2019-1-14 @ 05:15
NJRoadfan wrote:That board might be Intel's first ATX form factor board. It dates to late 1996!
The Intel Advanced/ATX (Thor) with a 430FX chipset was actually Intel's first ATX socket 7 board. it's from early-mid '96, mine's from late '96 and is flashed with a MR BIOS
1996-VX97,P133,32MB-RAM,TRIO-64V+,CT1740
1997-AN430TX,P200MMX,64MB-RAM,VIRGE-DX,Voodoo2-8MB,CT1740
2017-ROG-B450F,R5-1600,16GB-RAM,GTX-1060
User avatar
Windows9566
Return to System Specs
Who is online
Users browsing this forum: No registered users and 4 guests
