First post, by Formulator
Restoration of an Intel Advanced/ML (Marl)
Socket 7 ATX/P133/256KB L2
82430HX
Aug-1996
Found in barn on countryside, quite filthy.
Rather simple beige box.
Found stripped of all parts save the processor. Add 32MB EDO, Fireball ST, and the rest.
MeuMqAE.jpg?1
Reply 1 of 17, by Anonymous Coward
Nice Inwin. This is what a proper system from the mid 90s should look like...with period correct drives and all.
Reply 2 of 17, by Munx
Great find!
I have the same board and it's really nice to work with - great design for cable management and proper ATX formfactor.
The only couple of issues I ran into were a 200MHz CPU limit and and it didnt't want to post with a K5 in it. Though Im sure that can be adressed with a bios update.
My builds!
The Underdog - The budget K6
Reply 3 of 17, by Andy1979
Looks great - have also just built a system with one of these boards. Latest BIOS update is worth installing as it enables booting from CD and fixed some issues I was having with Windows 95 detecting both IDE channels properly.
Think they are limited to non-MMX Intel CPUs (or the MMX overdrive) which isn't surprising for an Intel-made board. Couldn't get mine to run with a 6x86 PR166+.
My Retro systems:
1. Pentium 200, 64mb EDO RAM, Matrox Millennium 2mb, 3DFX Voodoo 4mb, DOS6.22 / Win95 / Win98SE
2. Compaq Armada M700 laptop, PIII-450, Win98SE
3. Core2Duo E6600, ATI Radeon 4850, Win XP
Reply 4 of 17, by chinny22
nice work, that empty spot for a case badge would annoy me, but was quite common back then
Reply 6 of 17, by Formulator
Good point, perhaps I could duplicate this badge from another system, as it is my favorite:
Reply 7 of 17, by probnot
Formulator wrote:
Good point, perhaps I could duplicate this badge from another system, as it is my favorite: […]
That badge looks like it's from the 1950's. Like if you got grandma to knit a case badge. I love it.
Reply 8 of 17, by karpmmx
I know this is an old topic, but does anyone here have Any detailed specs on the Marl board? I just picked up an old TriGem PC with this board, and can't find any information on it, beyond the chipset and processors supported. TriGem is long since defunct.
Reply 9 of 17, by detritus olentus
Chanced upon this thread and really liked the long-ago-mentioned case badge so I played around in Gimp and MS Paint with my amateur skills. I'm also colorblind so any shade changes I blame on that.
85.39 KiB
https://drive.google.com/open?id=11NaRxwCXP0K … tpGRNu2rbaWYBRG
https://archive.org/details/@detritus_olentus
Philly Burbs.
Reply 10 of 17, by Formulator
Here are the specs:
http://www.bcmcom.com/tech/sq598/28180602.pdf
Also, nice work cleaning up that case badge image.
Reply 11 of 17, by Windows9566
NJRoadfan wrote:
That board might be Intel's first ATX form factor board. It dates to late 1996!
The Intel Advanced/ATX (Thor) with a 430FX chipset was actually Intel's first ATX socket 7 board. it's from early-mid '96, mine's from late '96 and is flashed with a MR BIOS
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 12 of 17, by raerek
I recently got a motherboard just like this one with an Intel MMX CPU. And - maybe sounds silly - I am unable to turn it on. I have a PSU just like this: https://www.youtube.com/watch?v=lI7I6aMQ7QI and I can connect 20 of the 24 pins to the motherboard.
And what now? I hoped that there would be a pair of pins somewhere on the board to short them, but I cannot find them.
Should I connect the remaining 4 pins somewhere? Where?
I guess this is the specification for the moherborad (not sure): https://www.fermimn.edu.it/inform/materiali/e … bd/28180602.pdf
Any help would be welcome.
Reply 14 of 17, by Munx
raerek wrote on 2021-03-24, 17:35:
I recently got a motherboard just like this one with an Intel MMX CPU. And - maybe sounds silly - I am unable to turn it on. I h […]
If the your board is just like this one, then the pins for turning it on are in the top-right corner, next to the floppy connector and speed jumpers. Page 15 and 18 of the manual you attached - pins 4 and 5 need to be shorted to turn it on. This motherboard also does not support MMX CPU's, only original Pentiums, so you will need to get one of those if you want to at least boot it.
My builds!
Reply 15 of 17, by raerek
Munx wrote on 2021-03-24, 19:54:
Sorry for the late reply. I guess it is just like the one. And I would have never thought that the | SLEEP PWR | label meant that it is a sleep AND a power jumper:) Thank you.
And guess what - it is able to run an MMX processor - or I am wrong with my "exactly the same" statement. I will post pictures so it is going to turn out soon.
Thank you again:)
