new psu ?
First post, by scroeffie
hi i have a pentium mmx dos computer with a voodoo 2 cart and a isa soudcard Creative Sound Blaster CT3620
the stock psu is a seasonic 150g < do i need to upgrade to a newer atx psu ?
and how do i upgrade because the motherboard has a at connector !
thanks for the help
Reply 1 of 11, by kanecvr
150w AT psu is perfectly fine for a pentium 1.
Reply 2 of 11, by scroeffie
maybe i need to explain better the original psu that came with my dos computer is a seasonic 150 watt psu
a youtube person with the name phil is saying to upgrade the to a brand new psu atx because the old at psu can die anymoment and damage other parts
so what kind of new psu do i need brand etc and does it need somekind of adapter !
iam scared now that it wil brake my other hardware
i realy like you picture of the old pc case you have 😀
Do you guys on this forum upgrade to a new atx psu or just leave the old at psu ! how big is the chance it wil brake !??
back in the day i never knew of someone with psu problems or my self
Reply 3 of 11, by ODwilly
scroeffie wrote:
maybe i need to explain better the original psu that came with my dos computer is a seasonic 150 watt psu a youtube person with […]
Seasonic was and still is to this day a top tier PSU manufacturer. If you have a 150watt Seasonic psu the odds are still pretty good that it is a solid and safe unit to continue powering your system.
Reply 4 of 11, by chinny22
Its down to preventive maintenance
Just like a hard drive will die one day, so will the PSU, the difference is the PSU can kill other parts when it does, or maybe not, You just don't know
100% comes down to if you want to play it safe, I use old AT power PSU's myself but understand those who feel safer with a new PSU
If you do want to replace it just in case you will need something like this.
https://www.ebay.com/itm/ATX-20-PIN-to-AT-P8- … XkAAMXQ4uJSE26o
You need something to change the ATX power to AT style, but ATX power button is not the same as AT so you want something with the power button to mount to your case.
Your setup doesn't have any special or high power requirements, Any good brand PSU will be fine, and way more efficient then the old PSU as well,
Reply 5 of 11, by bjwil1991
It depends on the motherboard as there are three different Socket 7 motherboards:
One that has AT (P8/P9) only
One that has AT (P8/P9) and ATX
One that has ATX only
What is your motherboard manufacturer and model? Can you take a picture and post it on here?
Reply 6 of 11, by scroeffie
thanks all for the help ! 1 more question wat kind of psu brand is good ? and how much watt do i need ?
i have a pentium mmx 200mhz 64mb ram 1 soundblaster card voodoo 2 card and a floppy drive and hdd and cd rom drive
Reply 7 of 11, by Ampera
150-200w at the minimum. There are two types of companies that deal in PSUs. OEMs that actually make the supplies, and rebadgers that buy OEM supplies and slap their name on it.
The best OEM tends to be Seasonic. Corsair also makes supplies, but I think it's only their high end ones. You don't have to feel bad about buying rebadged supplies though. EVGA is a company that tends to pick decent mid range supplies.
Rarely should you ever skimp on a PSU, but if you absolutely must,. I have had good luck with cheap Logisys supplies. Few have broken that I know of, but not in my hands, and they didn't take any components with them
However if you can spare the cash, get a new Seasonic, or just keep yours. This is before the capacitor plauge really hit companies hard, so the supply should be fine for at least another decade or so.
Reply 8 of 11, by deleted_Rc
ehm, I doubt Phil would say something like this but its possible. My current unbranded PSU which I have lying around for test purposes doesn't require a recap, since the caps have like new values. There are only 2 reasons to replace a PSU: 1. caps are bulging and 2. you need more juice.
You can replace caps easy yourself if you have a decent soldering iron (small one) and since your current one is sufficient I wouldn't replace it at all and just recap it if needed.
Reply 9 of 11, by F2bnp
If you can tell us the model of your motherboard, we can tell you if you need an adapter like the one chinny22 mentioned or not.
As others have said, the Seasonic 150W is more than adequate, but if you want to play it safe, even Corsair's low end VS350 PSUs will be suitable for such a system.
Reply 11 of 11, by kanecvr
Even if the old PSU fails, there's little to no chance of it taking other hardware with it considering it's a well known brand. If you're worried about it, recap (change capacitors) the 150w AT PSU and you'll be fine. Using an ATX PSU + AT converter on an old machine is more trouble then it's worth. Besides the obvious (and unnecessary) expense and complication, you will loose the -5v rail (ATX PSUs don't have that) witch will cause issues with some ISA soundcards and even some motherboards (some 386/486 and early socket 5 boards don't correctly interpret the Power Good signal off modern ATX PSUs)
If you want to do something for your old rig, get the PSU to a specialist and have the capacitors replaced - or buy a soldering iron and materials and have a go at it yourself - it's quite easy once you get the hang of it.
