First post, by Lightseeker
I'm trying to get these cheats to work with the PC version of "Bram Stoker's Dracula" (Psygnosis) which I have running in DosBox. I basically know what a hex editor is, but I can't figure out how to get those cheats to work because it doesn't even tell you which executable to use the editor on 🙁
Please, if someone is good with Hex-Editors and can explain it or even modify the file for me (I can send the *.bat file), it would be much appreciated. Here is the link to the cheat:
http://www.cheatchannel.com/files/bramstrd.htm
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The game was released for many platforms, and the page you linked doesn't make clear it's for the DOS release.
Reply 2 of 3, by Osprey
It's probably drac.exe that needs to be edited. I went ahead and did it for you. It's untested, though.
Reply 3 of 3, by JShone2025
Osprey wrote on 2017-11-05, 21:04:
You need to save a saved game then edit the saved game file. You need to edit a .sav file not drac.exe.
I have been playing this game since downloading it on CompuServe around 1997 on a Viglen 386SX PC with sound blaster. Forgotten how much I enjoyed it!
