Myth II: Soulblighter won't run [SOLVED]
Getting old software/games running on older hardware.
Postby bjwil1991 » 2017-11-13 @ 02:43
I have a copy of Myth II: Soulblighter for Windows, and when I try to run the game, even if there isn't anything running in the background, I get this error message:
Error message when trying to launch Myth II.
It's trying to run on a Socket 370 system with the following specs:
Shuttle AV18 V3 motherboard
VIA Apollo Pro 133A chipset
VIA AC'97 Audio (Sound Blaster compatible)
512MB SD-RAM PC-133
VIA C3 700A 700MHz CPU
200GB Maxtor 6Y200P0 IDE HDD (DMA enabled in Windows) <-- Limited to 32GB using SeaTools for DOS since the drive was used in the K6/2-300 system previously which has HDD space limitation up to 32GB
LG CD Burner (DMA enabled in Windows)
Gigabyte 52x CD-ROM Drive (DMA enabled in Windows)
3.5" 1.44MB FDD
Windows 98SE
400W Diablotek PSU
Compaq Keyboard and Mouse
JBL Platinum speakers with monitor mounts (special CRT monitors).
ASUS V3800M/32M (nVidia Riva TNT2 M64 AGP 4x/2x)
RealTek RTL8139D FastEthernet PCI Card
NEC MultiSync LCD1530V
Every other game runs without issues, just this game doesn't want to throw the dice.
Should also mention, I have enough storage space on my HDD:
Enough storage space.
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 462, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Re: Myth II: Soulblighter won't run
Postby UCyborg » 2017-11-13 @ 05:09
Install the latest patch.
UCyborg
Re: Myth II: Soulblighter won't run [SOLVED]
Postby bjwil1991 » 2017-11-15 @ 02:49
Got the game to work after installing the patch. Thanks.
User avatar
bjwil1991
Postby vandenabeele andries » 2017-11-20 @ 17:21
God Myth 2. I remember playing the demoversion of that.
Havnt played that in at least 15 years.
Where did you find the copy?
User avatar
Postby bjwil1991 » 2017-11-20 @ 18:14
vandenabeele andries wrote:God Myth 2. I remember playing the demoversion of that.
Salvation Army. It looks like Command and Conquers/Civilization mashup developed by Bungie.
User avatar
bjwil1991
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
