First post, by bjwil1991
I have a copy of Myth II: Soulblighter for Windows, and when I try to run the game, even if there isn't anything running in the background, I get this error message:
23.01 KiB
Error message when trying to launch Myth II.
It's trying to run on a Socket 370 system with the following specs:
Shuttle AV18 V3 motherboard
VIA Apollo Pro 133A chipset
VIA AC'97 Audio (Sound Blaster compatible)
512MB SD-RAM PC-133
VIA C3 700A 700MHz CPU
200GB Maxtor 6Y200P0 IDE HDD (DMA enabled in Windows) <-- Limited to 32GB using SeaTools for DOS since the drive was used in the K6/2-300 system previously which has HDD space limitation up to 32GB
LG CD Burner (DMA enabled in Windows)
Gigabyte 52x CD-ROM Drive (DMA enabled in Windows)
3.5" 1.44MB FDD
Windows 98SE
400W Diablotek PSU
Compaq Keyboard and Mouse
JBL Platinum speakers with monitor mounts (special CRT monitors).
ASUS V3800M/32M (nVidia Riva TNT2 M64 AGP 4x/2x)
RealTek RTL8139D FastEthernet PCI Card
NEC MultiSync LCD1530V
Every other game runs without issues, just this game doesn't want to throw the dice.
Should also mention, I have enough storage space on my HDD:
45.54 KiB
Enough storage space.
Reply 1 of 4, by UCyborg
Install the latest patch.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 2 of 4, by bjwil1991
Got the game to work after installing the patch. Thanks.
Reply 3 of 4, by vandenabeele andries
God Myth 2. I remember playing the demoversion of that.
Havnt played that in at least 15 years.
Where did you find the copy?
Reply 4 of 4, by bjwil1991
Salvation Army. It looks like Command and Conquers/Civilization mashup developed by Bungie.
