DOSBox-X branch
Here you can discuss the development of patches.
Re: DOSBox-X branch
Postby Paul Galbraith » 2017-11-09 @ 02:24
TheGreatCodeholio wrote:Not that I'm aware. I've been able to bring on some help to make Win32 builds so I can focus on cleanup and other projects.
I used the latest September 2017 win32 build and successfully installed Win 95 retail. Unfortunately I am finding it too slow to do what I want, which is to have a decent way to play Close Combat 1 -- VMWare hosting WinME is the best solution I've found so far, but still not ideal. Nontheless, thanks very much for all your hard work in getting the needed support into dosbox so that we can run Windows 95 with CD images. I'll be following closely, and hopefully one day (maybe I just need a better machine!) this will be great for playing CC1.
Paul Galbraith
Re: DOSBox-X branch
Postby Myloch » 2017-11-15 @ 14:31
Some bugs found in dosbox-x sept.2017 (emucr) build: when running a game, sometimes the monitor shows garbled graphics, it seems like the monitor doesn't fully refresh and it shows pieces of graphics from previous screens, maybe bug is triggered when it switches resolution/graphic mode from dos prompt to a random game? Using OpenGL mode.
In a windows 8.1 x64 pc I have to run dosbox-x several times before to successfully run the thing, most of the times it briefly shows a black window and then it aborts without errors. This problem doesn't affect my other Windows 7 x64 pc.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
User avatar
Myloch
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-01 @ 17:39
I've started releasing Windows binaries again. I still prioritize development on Linux though.
I just finished adding PC-98 emulation and several common games are playable in it.
DOSBox-X project: more emulation better accuracy.
DOSLIB and DOSLIB2: Learn how to tinker and hack hardware and software from DOS.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby Myloch » 2017-12-04 @ 15:22
TheGreatCodeholio wrote:I've started releasing Windows binaries again.
Nice! Where?
User avatar
Myloch
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-04 @ 16:53
GitHub, of course.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby AnnaWu » 2017-12-07 @ 08:16
TheGreatCodeholio wrote:I've started releasing Windows binaries again. I still prioritize development on Linux though.
Hello TheGreatCodeholio,
the DOSBox-X is very new for me. Please can you tell me something about the PC-98 emulation support?
So far I know I need the Anex86.bmp image and I have to modify the *.conf file (machine=pc98)
Do I need additional PC_98 BIOS ROMs?
Please can you tell me how can I load a *.FDI disk image?
Maybe you can give me an example for the *.conf file?
Thanks in advance!
Anna
AnnaWu
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-07 @ 09:08
BIOS and DOS calls are directly emulated by DOSBox-X (just as it does for IBM PC). No ROM is needed.
You can obtain ANEX86.BMP from various sites that offer the anex86 emulator.
In the latest build, IMGMOUNT has been updated to support mounting FDD/FDI images directly. Make sure you use -t floppy and that the image filename ends in .fdd or .fdi to help DOSBox-X identify that the image is FDD/FDI format.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-07 @ 09:11
Also understand that, while some games do run so far, many will not. PC-98 emulation is very early and experimental. Many BIOS calls are stubs and not implemented. Booter games are not supported. If you run these games from a folder (mounting a folder) and filenames are in Japanese, your host filesystem will need those filenames in UTF-8 unicode encoding, NOT SHIFT-JIS. DOSBox-X when mounting a folder will translate filenames (meaning convert from unicode to the MS-DOS code page) for the guest.
So far, the emulation is enough to run a handful of games (including Touhou Project and many PC-98 ports of IBM PC games) but don't expect the game to work.
EDIT: On Linux/Mac OS X the filenames will need to be in UTF-8. On Windows, the filenames must be converted to Unicode (wide char) UTF-16 so that they can be represented on the FAT32 or NTFS filesystem properly, which DOSBox-X will convert to the guest code page on file access.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby danrevella » 2017-12-07 @ 09:40
Hi!!
At the moment the bios support for int 10h 1c02h is still broken.
Any help please?
danrevella
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-07 @ 09:49
Are you saying that VGA state is not being saved/restored properly?
http://www.ctyme.com/intr/rb-0222.htm
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby AnnaWu » 2017-12-07 @ 15:26
TheGreatCodeholio wrote:BIOS and DOS calls are directly emulated by DOSBox-X (just as it does for IBM PC). No ROM is needed.
Thanks for the help, TheGreatCodeholio.
I tried Rude Breaker but unfortunately I have no sound.
Tested on Windows Vista.
If the sound is working please tell me the settings or upload the working *.conf file.
You do not have the required permissions to view the files attached to this post.
AnnaWu
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-07 @ 16:54
FM emulation is on by default at the moment. I was not aware Rude Breaker had any sound.
But sound works just fine with Rusty, Edge, Gods, DGA, and Touhou Project here on Linux.
EDIT: All I did for sound was port Neko Project's FM 86-board emulation to DOSBox-X. I did not port the CS4231 emulation. What sound hardware is Rude Breaker expecting to talk to?
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby AnnaWu » 2017-12-08 @ 08:39
I guess Rude Breaker use the YM2203 sound chip (FM Operator Type-N)
AnnaWu
Re: DOSBox-X branch
Postby danrevella » 2017-12-09 @ 10:55
TheGreatCodeholio wrote:Are you saying that VGA state is not being saved/restored properly?
yes, so many cheat utility like game buster and Infinity machine are unable in working...
when you return to the game the screen is black.
danrevella
Re: DOSBox-X branch
Postby Great Dragon » 2017-12-09 @ 20:07
Hey TheGreatCodeholio,
Any chance to see OPL3 and another SoundBlaster fix in your build?
What about FluidSynth support?
User avatar
Great Dragon
Re: DOSBox-X branch
Postby AnnaWu » 2017-12-11 @ 12:01
Dear TheGreatCodeholio,
PC-98 Emulation
I think the the *.HDI hard disk file format is not supported. Is it ok if I convert the *.HDI format to the *.IMG raw disk format and run it on the DOSBox-X?
AnnaWu
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-11 @ 18:19
I just look at what I/O ports are being probed on startup.
Rude breaker seems to check I/O ports 0x88-0x8F and 0x288-0x28F for FM synthesis.
DOSBox-X at this time emulates the -86 board and places it at port 0x188.
Even when I moved the FM to port 0x88 Rude Breaker didn't seem to talk to it, so it probably assumes the -26 board or some other type.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-11 @ 18:21
Great Dragon wrote:Hey TheGreatCodeholio,
What about Sound Blaster? Is there a use case that needs to be fixed?
FluidSynth support is already there. It was inherited either from Ykhwong's branch or the main project (don't recall exactly). It still works and it sounds great on my Linux system given the most recent sound font file available.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby TheGreatCodeholio » 2017-12-11 @ 18:24
AnnaWu wrote:Dear TheGreatCodeholio,
PC-98 Emulation
You can. However for PC-98 there's more than just going through the MBR. NEC PC-98 DOS seems to define only one partition then subdivide by it's own proprietary bootloader's partition list.
Given the weekend to do it, I was able to add FDD and FDI support, but didn't get around to HDI yet.
To support mounting HDI as a filesystem the code would have to identify that it's HDI. To mount the filesystem, it would have to identify NEC's bootloader/bootmenu, and then read the proprietary IPL table to locate the actual MS-DOS filesystem. The only reference I have to the IPL table is some bit of source code in GNU parted.
Considering the number of games I've found distributed as HDI images I definitely want to support mounting them as a hard drive in order to play those games.
User avatar
TheGreatCodeholio
Re: DOSBox-X branch
Postby AnnaWu » 2017-12-12 @ 07:42
Thank you for the answer and your great help, TheGreatCodeholio!
AnnaWu
PreviousNext
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
cron
