Just run it on the PS/2 P70 and I get:
Parallel port(s) found: 1
LPT1 3BCH standard (output-only)
My old Thinkpad says bi-directional
SteveC wrote:Just run it on the PS/2 P70 and I get:
640K!enough wrote:SteveC wrote:Just run it on the PS/2 P70 and I get:
I'm a little surprised that the first parallel port is configured to use 3BCH; I thought that was only on even older machines. I looked at the source code to the TSR early on, but don't remember if it supports that configuration.
With it being an output-only port, my theories about the problems being related to parallel port mode/type are definitely not relevant.
matze79 wrote:Hm i will test it on PS/2 Model 40SXReport back later..
derSammler wrote:I encounter one problem however: with the OPL2LPT connected and powered (from USB), I can no longer boot Windows 98 SE. It just completely freezes the system at the boot screen.
Scali wrote:I just built mine, tested it with my Celeron Northwood laptop with my custom-hacked DOSBox, and it works!
snow9 wrote:Hi everyone, I just made an account here to post about my OPL2LPT which recently came in the mail. I can confirm that it is working on my PCjr, which is awesome because that computer was never intended to have Adlib support or even a parallel port really.
The first game I tried was Fun Seeker's Guide, but that one gave me the following error: "0x89/3 not found." So I tried Colonel's Bequest instead and the Adlib support works beautifully on that game. I'd be playing it right now except that for some reason I can't get the PCjr graphics to load. CGA works fine and even Tandy 1000 loads in a garbled state, but when I select PCjr it just stops loading for some reason. I actually had the same issue when I tried testing Fun Seeker's Guide before patching it. Does anyone know what might be causing this?
dreamblaster wrote:1st prototype... (Still waiting for the yamaha chips to arrive)
Users browsing this forum: tgod and 1 guest
