First post, by Shane32
- Newbie
I'm having problems with the fpu enabled on DosBox-X 12-31-2017. To illustrate, this one-line BASIC program returns 0 (false) instead of -1 (true):
PRINT VAL("1") = 1
With the FPU turned off it works fine. I've tried all the core and cpu settings, but no matter what, the example above fails whenever the fpu is enabled. This can be seen in the BASIC game NIBBLES (included with MS-DOS 5) where the game will not accept a response to "number of players?", or the game Operation Neptune, in which the built-in calculator always responds with "answer too large" and will not accept a correct answer.
Is this a bug in the fpu emulation? Or is there another setting I'm missing to properly emulate a 80486DX2 (which should include a fpu)? It would seem that when core=simple, the fpu should simulate a fpu from that era, even if the answers are a bit different from when core=dynamic.
Note that the problem does not occur with Dosbox 0.74. I'm guessing it does not emulate the fpu at all.
My setup is:
Doxbox-X 12-31-2017 build
Windows 10 64 bit
Intel Core i7-7567U 3.5GHz / 16GB RAM / integrated graphics
My config is:
[sdl]output=direct3dfullscreen=true[dosbox]a20=mask[render]aspect=truescaler=normal3x[cpu]core=autocputype=autofpu=truecycles=25000[midi]mpu401=uart
I'm using MS PDS 7.1 BASIC within DosBox.
Thanks!
Shane
