First post, by Shane32
I'm having problems with the fpu enabled on DosBox-X 12-31-2017. To illustrate, this one-line BASIC program returns 0 (false) instead of -1 (true):
PRINT VAL("1") = 1
With the FPU turned off it works fine. I've tried all the core and cpu settings, but no matter what, the example above fails whenever the fpu is enabled. This can be seen in the BASIC game NIBBLES (included with MS-DOS 5) where the game will not accept a response to "number of players?", or the game Operation Neptune, in which the built-in calculator always responds with "answer too large" and will not accept a correct answer.
Is this a bug in the fpu emulation? Or is there another setting I'm missing to properly emulate a 80486DX2 (which should include a fpu)? It would seem that when core=simple, the fpu should simulate a fpu from that era, even if the answers are a bit different from when core=dynamic.
Note that the problem does not occur with Dosbox 0.74. I'm guessing it does not emulate the fpu at all.
My setup is:
Doxbox-X 12-31-2017 build
Windows 10 64 bit
Intel Core i7-7567U 3.5GHz / 16GB RAM / integrated graphics
My config is:
[sdl]
output=direct3d
fullscreen=true
[dosbox]
a20=mask
[render]
aspect=true
scaler=normal3x
[cpu]
core=auto
cputype=auto
fpu=true
cycles=25000
[midi]
mpu401=uart
I'm using MS PDS 7.1 BASIC within DosBox.
Thanks!
Shane
Reply 1 of 4, by Zup
You should check it on a real DOS machine, because this may be a BASIC issue.
I mean... what kind of data is 1 and what kind of data returns VAL()? Maybe you are comparing a integer number with a float, and in some languages this can lead to unexpected results.
I'm selling some stuff!
Reply 2 of 4, by collector
You might want to post this in the DOSBox-X thread to be sure that TheGreatCodeholio sees it.
DOSBox-X branch
Reply 3 of 4, by Shane32
You're correct - VAL returns a double, and then it's compared to an integer. With single-precision variables, there isn't a problem.
I don't know about the rest, but I never remember a problem with NIBBLES or Operation Neptune on my old 486DX2-66 machine that I grew up on.
There is a MS KB article about comparisons in BASIC, but ... it did work ...
https://support.microsoft.com/en-us/help/6933 … arison-problems
I have not found any FPU-testing programs online. So for now I'll just leave the fpu disabled. None of the software I'm emulating requires a fpu anyway.
Reply 4 of 4, by BlackJack
Dosbox 0.74 seems to always have an FPU. I wasn't able to configure it so that this simple test program doesn't detect an FPU:
; nasm fpu_test.asm -o fpu_test.com
cpu 8086
org 100h
start:
mov dx, no_fpu_txt
fninit
fnstsw [fpu_status]
cmp word [fpu_status], 0
jne .nope
fnstcw [fpu_control]
cmp word [fpu_control], 037fh
jne .nope
mov dx, fpu_txt
.nope:
mov ah, 09h
int 21h
mov ax, 4c00h
int 21h
no_fpu_txt:
db "No "
fpu_txt:
db "FPU found", 13, 10, '$'
fpu_status:
dw 0ffffh
fpu_control:
dw 0ffffh
The setting `fpu=false` is neither documented in the config file or man page, nor does it have any effect on my 0.74 installation.
    fpu_test.zip
    614 Bytes
    84 downloads
    Source & COM
“The city's central computer told you? R2D2, you know better than to trust a strange computer!” — C3PO
