Newly made Gravis Ultrasound compatible cards ... what's the degree of interest?
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Newly made Gravis Ultrasound compatible cards ... what's the degree of interest?
Postby shock__ » 2018-1-03 @ 08:46
"Good" news everyone. I can reproduce the RAM check fail on all revisions of the prototype _as well as_ on the original GUS PnP.
Gonna try to reproduce that on another system later today and if that happens try to investigate what's going on there.
User avatar
shock__
Postby 640K!enough » 2018-1-04 @ 00:30
Did you plan to share the steps to reproduce the behaviour once it is confirmed? Is the official InterWave memory test reporting the problem?
640K!enough
Postby shock__ » 2018-1-04 @ 13:15
Yup, it's the RAM test in setup.exe of the GUS PnP reporting RAM errors. If I can confirm it's a bug with the hardware/software I'll share how to reproduce them ... currently signs are towards wrong settings of my mainboard.
User avatar
shock__
It's happening!
https://i.imgur.com/hgWp4vi.jpg
You'll all get PNs with your tracking numbers shortly after this post.
EDIT: You all should have messages with your tracking numbers in your inboxes now.
User avatar
shock__
Postby hard1k » 2018-1-04 @ 13:20
Oh my... :)
Please have a look at my wishlist (hosted at Amibay)
User avatar
hard1k
Postby Phreeze » 2018-1-04 @ 13:50
:kiss:
we need a "love smiley" ;)
ArGUS Parts list: http://bit.ly/2Ddf89V
User avatar
Phreeze
Postby 640K!enough » 2018-1-04 @ 16:35
shock__ wrote:currently signs are towards wrong settings of my mainboard.
Maybe not related, but I've noticed that the InterWave doesn't like having a high I/O recovery time on the ISA bus. In my case, it produced distorted MIDI playback (screeches and beeps) eventually, but I never bothered with the memory test. Reducing the recovery time fixed that problem, so the InterWave is somewhat sensitive to these settings.
640K!enough
Postby matze79 » 2018-1-05 @ 12:49
Thanks my Prototyp has arrived, No. 14 is now sitting on my Desk, waiting for parts :)
https://www.retroianer.de
matze79
Postby moturimi1 » 2018-1-05 @ 21:11
My Prototype has arrived too. No. 11
I have to order parts this weekend.
I hope my solder skills are good enough to get it done.
I am sort of a novice in this aspect.
moturimi1
Postby King_Corduroy » 2018-1-05 @ 21:15
Maybe I'm misunderstanding but hell yes if it was a 1:1 clone that worked on old machine I'd be all over that. Also though someone mentioned Amiga? Could the Amiga soundset be made into a PC compatible soundcard? That would be freaking amazing. lol
Check me out at Transcendental Airwaves on Youtube! Also wtf, why are whoppers so good?!
User avatar
King_Corduroy
Postby shock__ » 2018-1-06 @ 00:07
No (it started out as a simple clone, but has long progressed) and hell no.
Fuck Amiga.
User avatar
shock__
Postby King_Corduroy » 2018-1-06 @ 03:09
Lol Such hate, I must agree. I love the C64 and 128 but I don't care much for the Amiga although I have a pristine one in boxes.
User avatar
King_Corduroy
Postby Batyra » 2018-1-07 @ 13:21
Phreeze wrote:i updated the shopping basket for 3 cards:
http://www.digikey.lu/short/qq9nnb
btw i can't edit older posts...what's the point....
Have not received my prototype yet, but I have allready ordered parts from Phreeze basket on Digi-Key - once again thanks.
Funny is that ordering parts for three is cheaper than order for two cards because with three there are no shipping costs.
So the only parts I may need (to done all the proper way) are DRAM (that can but not have to be used in slot) and that metal "bracket" - don't know how to call it?
User avatar
Batyra
Postby Ozzuneoj » 2018-1-08 @ 05:27
I've never personally experienced an Ultrasound, but I check this thread all the time. It completely blows my mind that someone has designed and is now producing (on some level) a modern remake of a vintage sound card.
I'm definitely interested in getting a later revision of one of these. I just lack the skills and knowledge needed to make use of a development board... :)
Time Machine = FIC PA-2013 2.1 - K6-2 500 - 256MB PC-100 - TNT2 Pro 16MB AGP - Labway Yamaha YMF719-E - Midiman MM401
Amibay For Sale Threads
I have lots of PC stuff for sale on Mercari! Get a $10 sign up credit with invite code VBGQMM.
User avatar
Ozzuneoj
Postby Batyra » 2018-1-08 @ 09:19
I don't know if I understood properly so please help.
How many DRAM modules I need (yes I know they are optional). I'm saying of these:
https://pl.mouser.com/productdetail/issi/is41c16105c-50kli?qs=sGAEpiMZZMti5BT4iPSEnXmjY%252buK6gYSEjdeFNR3lUU%3D
EDIT: I found these modules for 4,38USD each (IS41C16105C-50KLI)
I don't need any sockets as all DRAM etc may be soldered directly? Yes?
User avatar
Batyra
Postby shock__ » 2018-1-08 @ 16:27
Bill of materials - as well as the footprint- should be obvious enough.
You can solder up to 2 DRAM chips directly onto the board, a single one or none would also work. Keep in mind sockets are only supported for 40 pin chips, 42 pin ones need to be soldered directly onto the board.
If anyone succeeds in socketing those, give me a ring. I attempted that a few days ago, gave up and resorted to soldering those directly on board.
User avatar
shock__
Postby Batyra » 2018-1-08 @ 17:48
Ok, thanks.
User avatar
Batyra
Postby keropi » 2018-1-08 @ 19:04
Isn't the better option to leave the onboard ram unpopulated and use the simm socket?
User avatar
keropi
Postby shock__ » 2018-1-08 @ 22:43
Anything goes (that's what the added pullups R1-R9 are for) - just make sure to select the desired configuration via JP0-JP3 & JP6 & JP7
User avatar
shock__
Postby Chain-Q » 2018-1-09 @ 13:57
shock__ wrote:Fuck Amiga.
Meanwhile, I have a Gravis Ultrasound in my Amiga. Haters gonna hate. 8)
https://twitter.com/chainq/status/931975028819791873
AMD K6-III+/400@550, 512MB, Diamond Stealth V550, Gravis Ultrasound MAX 1MB, Sound Blaster AWE64
C= Amiga 2000, Motorola 68060@50, 128MB, Cirrus Logic 5446A 4MB, ESS 1688 + Intel 80386sx@20 8MB
Member of the Free Pascal Compiler team, Twitter: @chainq
User avatar
Chain-Q
PreviousNext
Return to Sound
Who is online
Users browsing this forum: No registered users and 2 guests
