First post, by matze79
i have a PowerMac G5 1,8Ghz DP (One CPU is missing.)
PCI-X and AGP. 4 Ram Slots. ATI 9600XT 256Mb, 3Gb DDR1.
Does anyone know if it will run 8Gb RAM ? 4x2Gb ECC DDR1 ?
I also have Leopard Image, but have no DL Layer DVD-R,
is it possible to create a Bootable USB Stick ?
I tried already to write the ISO with Transmac, unfortunaly it does not boot from OBP.
USB Device is listed, and it tries to load Stuff.
But then it goes back to the "Can't load Icon"
I'm currently running Ubuntu 16.04 on it.
i also compiled lwgl and can run Minecraft now.. but IBM Power4 32bit Java is slow as hell... 😀
Don't know why Java is slow... even a PIII 1Ghz does better.
Thanks
Matthias
Reply 1 of 28, by bjwil1991
https://everymac.com/systems/apple/powermac_g … _g5_1.8_dp.html
And it looks like 8x1GB DDR memory is supported only (if my memory serves me right as I've never owned one at all), but, yes, you can put 8GB RAM in there.
Reply 2 of 28, by lazibayer
For RAM, I think you can only max it out at 4x1GB. Not sure about the ECC part.
https://everymac.com/systems/apple/powermac_g … -ram-slots.html
For OS, this method looks plausible, though I didn't try it. You might need another working mac.
https://gwhiz.wordpress.com/2006/09/21/instal … opard-from-dmg/
Reply 3 of 28, by bjwil1991
His PowerMac G5 has the PCI-X slots, not PCI, which supports 8x1GB RAM.
Reply 4 of 28, by lazibayer
The OP explicitly said 4 RAM slots. AFAIK only the last generation G5 with PCI-E slots can support single 2GB sticks, in DDR2, with processors faster than 2GHz DC.
I know PCI-X models should have 8 RAM slots but I tend to believe the OP did a better job at counting RAM slots than telling the difference between PCI and PCI-X.
Reply 5 of 28, by matze79
It has 4 RAM Slots and PCI-X for sure 😀
Apple says ECC RAM is ok, but i can't find Information about DIMM Size.
Also 8Gb supported.. but i have only 4 DIMM Slots 😳
EDIT: only DDR2 Models support ECC ?
Seems Page Information is incomplete ^^
Too bad i have no ECC RAM to try it.
    69.47 KiB
    49.83 KiB
    123.95 KiB
Reply 6 of 28, by lazibayer
matze79 wrote:
It has 4 RAM Slots and PCI-X for sure :) […]
I reckon those are PCI slots. They are 3.3V 64bit PCI slots and have the same appearance as 64bit PCI-X slots.
Reply 7 of 28, by matze79
So you mean only 32bit Part is connected ? hmm (EDIT: full 64bit is connected)
PCI-X = 64bit PCI or not ?
Where is the difference ? PCI-X vs 64bit PCI ?
Reply 8 of 28, by bjwil1991
PCI-X is a 64-bit data bus that is backwards compatible with 32-bit PCI cards and supports the following voltages: 3.3V, 5V, or both (universal), depending on the slot itself as displayed on this site: https://superuser.com/questions/384640/what-i … -and-pci-x-slot
There is no difference (generally) between PCI 64-bit and PCI-X in a matter of speaking.
Reply 9 of 28, by lazibayer
Conventional PCI tops at 66MHz 64bit, and PCI-X 1.0 pushed that limit to 133MHz 64bit.
PCI-X differs from PCI in more aspects than speed and bandwidth. It added split-response mechanism, message signaled interrupts and registered i/o on top of the conventional PCI.
Reply 10 of 28, by nforce4max
OCZ Platinums have been a default choice amongst some in the ppc mac community but anything with good timings and automatically works at those timings is a good choice as you will get a little bit of extra bandwidth which does help.
Reply 11 of 28, by matze79
Maybe i can solder in the 4 Missing RAM Slots, or is it limited by chipset ?
Can i also put in a 2Ghz CPU and run it at 1.8Ghz? or do i need 100% matched pairs ?
i always wanted a IBM Power4/5 Machine, and a G5 is the cheapest option i found 😀
Anyone knows if it will run AIX too ?
Reply 12 of 28, by PTherapist
It won't. It's not a Power 4/5 machine, despite similar CPU.
There are Linux distributions available, as well as flavours of OpenBSD and freeBSD. But generally Mac OS X is about the best and most supported OS you can run on it.
Reply 13 of 28, by matze79
I installed tiger, but its pretty hard to source software except Opensource Stuff you can compile yourself.
What about Gaming on G5 ?
Is there something else then Doom 3 and Quake ? 😁
Reply 14 of 28, by lazibayer
I played Warcraft3 on G4 and G5.
With Tiger you can run OS9 games in classic mode.
Reply 15 of 28, by matze79
thats why i installed tiger 😀
What about Apple Only Games for OSX ?
Whats Apple's Halo ?
Reply 16 of 28, by lazibayer
Check the requirements. If it says Intel-only then no-go.
Halo CE has official support for PPC so should be good. Halo2 has unofficial PPC port so might be good.
Reply 17 of 28, by bjwil1991
Halo CE requirements for Mac is this:
Minimum
PowerPC G4 800MHz
256MB RAM free
32MB Video (nVidia GeForce2 MX/Radeon 7000)
Mac OS X Jaguar (10.2.8)
1.4GB Free HDD space
Recommended:
1GHz CPU (PowerPC G5* or higher)
512MB RAM free
64MB Video(GeForce4 or higher-ish)
Mac OS X Jaguar (10.2.8) or higher
1.4GB HDD Free space
*Don't know if this is right or not.
Reply 18 of 28, by Unknown_K
The first Powermac G5 tower (single 1.6ghz G5) shipped with 10.2.7 so the recommended requirements make sense.
Anyway the 4 RAM slot models are PCI and are stuck at 4GB of RAM. 8 RAM slot AGP models are PCI-X and can do 8GB of RAM. The PCIE models have 8 slots and can do 16GB (2x8GB) but I have no idea if you could actually need all that RAM.
Reply 19 of 28, by matze79
Yeah i didnt mean halo, i mean Apple "Exclusive" Games, only on OSX 😀
