DOSBox ECE (for Windows)
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox ECE (for Windows)
Postby truemaster » 2018-3-04 @ 11:48
im trying 2 games blood with 3dfx patch and tomb raider. both failed with cant find dll. about settings memory to 64mb also with more or less ram. output all options surfacepp-np opengl etc. voodoo settings all options like auto opengl etc. the build is the final.
truemaster
Postby Yesterplay80 » 2018-3-05 @ 08:25
truemaster wrote:im trying 2 games blood with 3dfx patch and tomb raider. both failed with cant find dll. about settings memory to 64mb also with more or less ram. output all options surfacepp-np opengl etc. voodoo settings all options like auto opengl etc. the build is the final.
You seem to be missing the Voodoo driver file "GLIDE2X.OVL", you can get that here. Just copy it it your BLOOD directory and it should work. Keep in mind though that the 3dfx patch for Blood is an alpha version and has many bugs!
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby truemaster » 2018-3-05 @ 16:49
thanks my friend. that solve it
truemaster
Postby James-F » 2018-3-24 @ 13:59
Hi YP80.
What is the difference between DosboxECE.exe and Dosbox.exe in the new ECE r4087?
User avatar
James-F
Postby Yesterplay80 » 2018-3-25 @ 12:25
James-F wrote:What is the difference between DosboxECE.exe and Dosbox.exe in the new ECE r4087?
DosBoxECE.exe shouldn't be in there, I just forgot to delete the binary, which was just a compiled experiment with more memory (up to 384MB).
User avatar
Yesterplay80
Postby olddos25 » 2018-3-28 @ 23:36
Cool! Maybe we could theoretically run Windows 95 with all that RAM available?
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Postby Yesterplay80 » 2018-3-29 @ 07:55
olddos25 wrote:Cool! Maybe we could theoretically run Windows 95 with all that RAM available?
Theoretically, yes. I didn't try it myself yet, though. And I still believe you'd be better off using DOSBox-X or PCem, those are surely way more optimized for running Windows.
User avatar
Yesterplay80
Postby KainXVIII » 2018-3-30 @ 11:52
viewtopic.php?f=41&t=49327&start=20#p661417 ECE build will implement this patch? =)
User avatar
KainXVIII
Postby James-F » 2018-3-30 @ 14:46
+1
@YP80, please update DosboxECE with NukedOPL v1.8.
User avatar
James-F
Postby Yesterplay80 » 2018-3-30 @ 23:28
Updated in DOSBox ECE r4088.2! :happy:
User avatar
Yesterplay80
Postby telanus » 2018-4-12 @ 11:34
Yesterplay80 wrote:Updated in DOSBox ECE r4088.2! :happy:
sadly no linux :(
My Retro PC:
Spec: PII400 with 400MB, Riva128zx and C-Media soundcard
OS: Win 98SE
Main:
Spec: Dual-Core 2.60, GeForce GT 240 3Gb Ram & Creative Audigy
OS: Win XP Pro (SP3)
User avatar
telanus
Postby Yesterplay80 » 2018-4-12 @ 12:03
sadly no linux :(
Nope, sorry, still no Linux builds.
Update: But maybe, if one would look again... ;)
User avatar
Yesterplay80
Postby telanus » 2018-4-13 @ 04:07
Yesterplay80 wrote:
sadly no linux :(
thanx
My Retro PC:
OS: Win 98SE
Main:
User avatar
telanus
Postby Thraka » 2018-4-24 @ 16:53
I haven't updated ECE for a while, it is my fav build though. :) Has any shader support been added yet? I miss the CRT look and feel.
User avatar
Thraka
Postby Yesterplay80 » 2018-4-25 @ 09:27
Thraka wrote:I haven't updated ECE for a while, it is my fav build though. :) Has any shader support been added yet? I miss the CRT look and feel.
No and it probably won't happen anytime in the foreseeable future.
User avatar
Yesterplay80
Postby Epsilon » 2018-5-01 @ 11:12
Just noticed you've put out Linux builds and source again. And I wanted to come here and say thanks! Much appreciated! :D
Epsilon
Postby tlk » 2018-5-01 @ 12:52
Epsilon wrote:Just noticed you've put out Linux builds and source again. And I wanted to come here and say thanks! Much appreciated! :D
It was perfectly buildable on Linux after some (rather trivial) changes to a couple of src files. Still good to see some much-needed Linux love here.
tlk
Postby Yesterplay80 » 2018-5-01 @ 19:22
You're welcome! :-D
Which changes were required exactly? The binary was compiled Linux Mint (32 Bit), so the source code shouldn't require any more changes. Or are there differences between Linux distributions that require changes in the source?
User avatar
Yesterplay80
Postby tlk » 2018-5-01 @ 21:26
You're welcome! :-D
He expressed joy that you've finally put out a Linux binary *and a Linux-specific source* - my comment referred to the time you didn't put out a special 'linux' source tree, yet one could relatively easily compile it on Linux anyway.
tlk
Postby Taiyoumaru » 2018-5-03 @ 10:29
Just a quick question, what's changed in ECE 4095.2?
Taiyoumaru
PreviousNext
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 2 guests
