Floppy Drive stuff
First post, by lorecast162
Hello. I have a Pentium 100 machine that I run DOS on (CDU DOS 7.1).
I wanted to install one of my games from floppy but the machine just doesn't like reading ANY floppy with ANY drive. In DOS when I do dir a: or anything that touches the A drive it says "Not ready reading drive A:", even when I have a floppy, I even changed the cable but that didn't fix it either.
It also doesn't want to boot from one, it just skips it, doing just one brief seek noise and passing to the HDD.
The machine has a dry Dallas chip that is unfortunately non-socketed and I kinda suck at desoldering so I didn't mod it.
Can somebody help me sort this out?
Reply 1 of 17, by kixs
Are you sure the floppies are in good condition and working on some other computer?
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 17, by appiah4
I have a similar issue with my BX-2000 board, I've tried multiple drives and ribbon cables, and multiple diskettes, it has issues reading disks. The said drives, cables and disks work in other systems. Is it possible for the FDD controller on a board to go bad like this?
Reply 3 of 17, by lorecast162
Yes, disks are working fine on my other old PCs
It could be, I have a similar issue with my 486, but that could be just the IO card i'm using. Instead of giving a not ready error, it says "General failure reading drive A".
I literally can't understand what's going on with these 2 machines, yesterday they were totally fine, now not so much
Reply 4 of 17, by Baoran
I had a similar problem. Everything worked fine except floppy drive and still it was changing the PSU that fixed the floppy drive problem.
Reply 5 of 17, by lorecast162
Alright then, I think sometime I will get some ATX PSUs and converters from Aliexpress.
Reply 6 of 17, by appiah4
Now I remember a similar case I had where moving the floppy and HDD to different 12V rails fixed it.. somerhing to try tonight!
Reply 7 of 17, by lorecast162
unfortunately only one mini MOLEX connector and no adaptors for FDD power D:
Reply 8 of 17, by appiah4
I'll be trying the floppy and hard drive on different rails, followed by a different, known working, quality PSU from an HP case if that should fail. I will post the outcome tomorrow.
EDIT: Replaced the floppy, ribbon cable, PSU, and the behaviour did not change. No idea what is wrong, it's probably the motherboard 🙁 Maybe I should just replace it with the BX2000+ I have lying about. Or try a third floppy drive?
Reply 9 of 17, by appiah4
Could we both be dealing with (in my case multiple) floppy disks with misaligned heads due to being knocked around etc? I will try tonight to see if my drive works in DOS and/or can read disks it formats itself.
Reply 10 of 17, by tayyare
Years ago (2010?) I throw a BX-2000(+?) to the garbage bin just because of same exact issue (PII/PIII boards was a cent a dozen at that times 😊). In addition to that, I still have a Gigabyte s370 board with the exact same issue. Everything works but the floppies. So, yes, it happens. 😠
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 17, by appiah4
Right.. I opened up and cleaned one of the floppies thoroughly including the magnetic heads, and will try it back on the system tonight. I'll try it under DOS, then I'll try formatting and read/writing a self formatted disk to eliminate other issues. I will finally hook up a GOTEK/HxC to the system to see if it can actually read fine from a disk image through an emulator. I should be able to pinpoint the exact issue that way. If it is a board thing, I can throw this away and try the BX-2000+. If that fails, I still have a GA-6BXC to finally fall back to..
Reply 12 of 17, by lolo799
It sounds like the common dead RTC battery issue and the cmos doesn't keep the floppy drive settings anymore,
add this at the beginning of your config.sys:
DRIVPARM=/D:0 /F:7
Read here for another person with the same problem/same solution:
1.44 floppy problem in DOS 6.22
Reply 13 of 17, by tayyare
lolo799 wrote:
It sounds like the common dead RTC battery issue and the cmos doesn't keep the floppy drive settings anymore, add this at the b […]
DRIVPARM=/D:0 /F:7
It was definitely not a dead CMOS battery thing. These boards I was talking about were slot 1 / socket 370 boards, thus with CR2032 batteries, which I change with a new one as soon as I start working with a board, as a principle. Haven't thought the DRIVPARM though, might have been worked.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 14 of 17, by tayyare
In my situation I tried almost all of the above. Trying in DOS, cleaning the drive, etc. Except Gotek. In my case, the problem was "drive not ready" thing so self formatting was not an option (the floppies, cables and drives that I tried was working just fine with other systems, though).
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 15 of 17, by oeuvre
you turn my floppy disk into a hard drive
Reply 16 of 17, by quicknick
Kinky^^
One of my 286 boards wouldn't keep the settings regarding floppy because of the dead Dallas chip, maybe that could be your problem too...
Reply 17 of 17, by appiah4
Just reporting that I fixed my issue. It was the floppy disks all along.
I had a bunch of (about two dozens) of Memorex branded 3.5" floppy disks I had bought second hand, they had a Win95 installation backup of some kind on them. I have successfully used them in other systems and with a USB floppy drive I have connected to my main desktop. However, with this PC, these floppies just don't work. Why, I do not know? I tried a Sony branded, much less beat up floppy and everything read and wrote perfectly fine.
I dumped the Memorex floppies. I have quite a score of spare floppies anyway, and I'm considering investing in a couple more gotek units soon, so it's no big issue. This was a genuinely weird turn of events regardless.
How can one system, with the same floppy drive, read an old floppy, but another system with the same drive can't? Floppy controller / floppy disk compatibility is something I never heard of before 😒
