DerSammler I chose express setup when installing 3.11 so it didnt detect a mouse and it didnt install any type of mouse, Jo22 I installed 3.11 from floppy and I used setup.exe or setup.com from the first floppy there are 9 disks I will look in the Windows dir to see it there is a setup.* to see if it will install a mouse as it sits right now but I have tried going to "Windows Setup" then "change system settings" then change "no mouse" to "install a mouse" and this is where it asks for the location of the mouse files so I tried my C:\Mouse folder it has 3 different mouse executable files ie: ctmouse.exe, mouse.com, bbbmouse.com but Windows does not like them and asks for the location of OEMSetup.inf, Rodoko I have loaded Dos using a mouse like ctmouse but when I run windows it does not transfer over and the mouse is not there.
I think I will just reinstall 3.11 and keep this in mind that a mouse should be connected at the time of install.
