cyclone3d wrote:Ok, looked through my cards and I don't actually have any with the 3112 chipset. […]
However, after a bit of research, I did find out that the ASUS A7N8X Uber 1007 BIOS has the SIL 3112 4.2.27 BIOS embedded in it.
Here is where you can get a link that you can use in the wayback machine to download it - the newest snapshot of the file is corrupted so I had to go back to an earlier snapshot. Because of this, I am attaching the 1007 Uber BIOS to this post.
https://tweakers.net/downloads/5438/asus-a7n8 … -bios-1007.html
1007-Uber.rar
You will need CBROM to extract the SIL 3112 BIOS. It is available here:
http://www.lejabeach.com/CBROM.html
Thanks a million cyclone3d!
Unfortunately this custom BIOS doesn't contain any changes related to the SATA controller,
The attachment 01.PNG is no longer available
but you did put me in the right track in a way I'd never thought. So I browsed through the official ASUS support for this motherboard and after downloading and using CBROM to check a couple of older BIOS' I found one having the desired version and extracted it:
The attachment 02.PNG is no longer available
It seems that the flashing utility is a bit smarter than it should though (or, most probably, prevents stupid people like me bricking their card) and recognizes that this BIOS is not intended for a standalone card:
The attachment 03.jpg is no longer available
Damn that was close!
marvias wrote:
Thank you so much for finding this, but unfortunately this is also a BIOS for a motherboard controller and not for a standalone card, the flash utility gives the same message as above (see last picture). Ahhhh and I got so excited seeing your post 🤣
