Daewoo AL486V-D BIOS needed
First post, by feipoa
I have one of these boards with version 298A BIOS, however, I see one of these motherboards on eBay with version 299 BIOS. Anyone have BIOS version 299 or later from a Daewoo AL486V-D and can share the image?
Stickers with 295 on them have BIOS identification string: 26XYR version 1.4
Stickers with 298A on them have BIOS identification string: 2600P version 1.7
299?
EDIT: These BIOSes appear to be produced or distributed by or for Leading Edge Products Inc, https://en.wikipedia.org/wiki/Leading_Edge_Hardware_Products
Unfortunately, I cannot find a website for them on wayback.
The attachment Daewoo_AL486-D_motherboard.jpg is no longer available
Reply 1 of 22, by feipoa
Nobody have this BIOS? Apparently "299" is version 1.9. Attached is an image I found online.
The attachment WinPro-d_version_1.9_299.jpg is no longer available
Reply 2 of 22, by feipoa
*bump*
Nobody have this "299" BIOS?
If anyone ends up buying this board from eBay, I'd be grateful if you could send me an image of the "299" BIOS. It is a fantastic board for 386+VLB. It doesn't have the 486 socket, which in my mind, makes it even better - PGA132 only. The jumpers are very simple compared to other 386 and 486 boards. Board works with SXL chips as well.
Reply 3 of 22, by GigAHerZ
OT:
Woah, i didn't know VLB is even possible with 386 processors! I have understood it's specific to the 486 architecture...
Does VLB work with the real 386 processors, or is it enabled only with 486DLC processors?
Reply 4 of 22, by feipoa
I'm not sure. I have only tested it with a 486DLC and 486SXL. I still have the board on my test bed, so I will try it with an Am386DX-40.
Reply 5 of 22, by feipoa
I am able to use the VLB graphics card with the Am386DX-40, however, to get the system to boot up, I had to set the "Cycle Check Point" to "Normal" instead of "Fast". Doing so nearly negates the performance benefit of using the VLB graphics card over an ISA graphic card.
The graphics cards utilised in this test were a CL-GD5434 ISA and an S3 Trio64 VLB. I used Doom shareware, timedemo 3, with the -nomouse and -nosound flags, although the drivers were loaded.
SXL-40
Cycle Check Point = Fast
VLB = 5215 = 14.3 fps
ISA = 6589 = 11.3 fps
26 % increase when using VLB on a 486SXL
386DX-40
VLB = system would not boot up, although it would count memory, run SCSI BIOS. Hangs just before POST.
ISA = 10591 = 7.1 fps
386DX-40
Cycle Check Point = Normal
VLB = 10346 = 7.2 fps
ISA = 12192 = 6.1 fps
2.4% increase when using VLB on a 386DX
Reply 6 of 22, by GigAHerZ
feipoa, thank you! Amazing thing.
386 with support (even if not very beneficial) is something i didn't think would exist.
Reply 7 of 22, by Tiido
386 support is in the VLB standard, only things that 386 cannot support with VLB are caching related stuff due to lack of internal cache and burst transfers support since the CPU is incapable of doing them. 386 and 486 buses are very similar still, those unsupported things are matter of only few extra signal lines.
Reply 8 of 22, by jesolo
@feipoa, is there perhaps a BIOS ID string appearing on the POST screen?
Based on the picture you posted, it appears to be AMI derived?
Reply 9 of 22, by feipoa
Yes, AMI-based. String here:
The attachment 298A_BIOS.jpg is no longer available
Reply 10 of 22, by jesolo
Interesting - based on the BIOS ID string, it identifies itself as an ECS (Elitegroup)/PC Chips BIOS.
Let me scratch a bit around and see if I come up with something.
EDIT: Seems like there was another user on here that had the same motherboard: Re: Need help to find jumpers for this motherboard...
Maybe he still has it?
Reply 11 of 22, by feipoa
Daewoo = ECS? Hmm...
He has it, but its stowed away in the back of some storage area without easy access. He doesn't know when he'll get to it.
Reply 12 of 22, by BastlerMike
Isn't this the same board as the ECS PANDA 386V ?
PANDA 386V BIOS:
Reply 13 of 22, by jesolo
It would appear so.
By using this info, I was able to track down another Vogons user that bought this particular motherboard (albeit with a different chipset - ETEQ). It would appear that there was also a MR BIOS for this chipset.
Reply 14 of 22, by feipoa
Unfortunately, that user hasn't been active in over a year. I remember sending him a PM months ago which went unread.
Reply 16 of 22, by feipoa
zoinknoise wrote:
i have uploaded v299 of this board's BIOS here.
Re: 80386 BIOS image collection
That is fantastic; thank you!
Reply 17 of 22, by kixs
I guess I missed this thread. I have Pandora version of this board. Can't remember if it has Mr.BIOS or not.
Also:
386DX-40 Cycle Check Point = Normal VLB = 10346 = 7.2 fps ISA = 12192 = 6.1 fps […]
386DX-40
It's 18% increase from ISA to VLB 😉
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 18 of 22, by pshipkov
Interesting.
It looks to me that this board is actually quite slow.
For reference, i am getting 14.7 fps in Doom with 386DX at 45MHz and 13 fps when at 40MHz, using ET4000AX, CL-5426 and other ISA cards.
I was expecting a mobo like this to be much faster than classic 386 ISA ones.
retro bits and bytes
Reply 19 of 22, by feipoa
kixs wrote:
I guess I missed this thread. I have Pandora version of this board. Can't remember if it has Mr.BIOS or not. […]
Also:
386DX-40
It's 18% increase from ISA to VLB ;)
What was your Cycle Check Point set as? Perhaps your BIOS is more optimised than mine. Can you share your BIOS and a photo of the motherboard?
