First post, by McBierle
Hello everyone, i got recently an PS/2 286 version. It works fine so far, one problem is, that there was no riser card with it.
I have the following riser card.
701.91 KiB
664.74 KiB
When inserted the monitor won't get a signal from the onboard video. From the few pics online it seems that the original riser is different, for example it has no resistors an caps.
Anyone know if i can modify my riser to work in that ps/2?
Greetings!
Reply 1 of 1, by McBierle
Ah forget it, i just tried to put some vga card in it and test. The cards a not reaching the backplate. About 2cm distance. 😀
I think i will try to get an original.
Thanks anyways
