First post, by McBierle
McBierle
Offline
- Member
Hello everyone, i got recently an PS/2 286 version. It works fine so far, one problem is, that there was no riser card with it.
I have the following riser card.
When inserted the monitor won't get a signal from the onboard video. From the few pics online it seems that the original riser is different, for example it has no resistors an caps.
Anyone know if i can modify my riser to work in that ps/2?
Greetings!
