First post, by xRipx
I looked around, I couldn't find this exact problem.
I'm running the latest DOSBox on my Raspberry Pi 3B+, slightly overclocked.
U.S. Navy Fighters, maxed out settings, runs very low FPS, totally unplayable. Maybe 10 FPS. If I reduce settings to lowest, it runs great.
I know that I can increase CPU cycles with ctrl + F12, however my F12 key on my mini usb keyboard requires me press Function + F2. I don't know if that is the reason, but the Ctrl + Fnc + F2 keystroke doesn't seem to do anything.
Is there a different way to increase cycles OR is there some other way to deal with this?
Thanks!
