First post, by xRipx
I looked around, I couldn't find this exact problem.
I'm running the latest DOSBox on my Raspberry Pi 3B+, slightly overclocked.
U.S. Navy Fighters, maxed out settings, runs very low FPS, totally unplayable. Maybe 10 FPS. If I reduce settings to lowest, it runs great.
I know that I can increase CPU cycles with ctrl + F12, however my F12 key on my mini usb keyboard requires me press Function + F2. I don't know if that is the reason, but the Ctrl + Fnc + F2 keystroke doesn't seem to do anything.
Is there a different way to increase cycles OR is there some other way to deal with this?
Thanks!
Reply 1 of 3, by leileilol
US Navy Fighters has a very slow texture mapper that stressed out all the high-end PCs of its time (e.g. Pentium 100s in Dec 1994, and many systems after that thanks to USNF's higher resolution support). Raspberry Pi 3B+s are not even cut out for it with the ARM dynarec as they'd emulate a 486DX4-100 at best on max. You will not want to play beyond VGA or have textures enabled.
long live PCem
Debian's fucked
Reply 2 of 3, by krcroft
I can also confirm limiting the Janes' games to 320x200 on the Pi3 to sutain playable frame rates.
(I also used cycles fixed at 29,000, the dynrec core, and a profiled optimized build of dosbox svn).
Reply 3 of 3, by xRipx
Ah, that's too bad. Thanks for the replies!
