First post, by cyclone3d
Well.. this is a blast from the past.
I did this back in the day before anybody was even talking about it. Saw that the Audigy 2 driver packs included support for the EMU10K chips and was like.. ok.. lame Creative.. let's just see if this works.. and it did.
Anyway, I dug up some old pages that talked about it as well as a guide on how to do it AND the driver patch file to add support for pretty much all the Live! and Audigy 1 and Audigy 2 cards, including OEM models out there.
ctcomp.zip
94.37 KiB
185 downloads
Here are the models listed in the patch file:
Audigy 2 ZS Series : SB0360/SB0290, SB0350/SB0250 , SB0352
Audigy 2 (NON-ZS) Series : SB0240/SB0250, SB0243, SB0242, SB0244/SB0250/SB0280/SB0290, SB0245, SB0244, SB0320/SB0290, SB0249
SB Audigy 2 LS : SB341
SB Audigy : CT4820, CT0070, CT0072, SB0090, SB0162, SB0092, SB0161, SB0192, SB0191, SB0091, SB0095, SB0230, SB0231, SB0232, SB0238
SBLive! 5.1 : For SB0060, SB0100, SB0102, SB0101, SB0103, SB0105, SB0221, SB0222, SB0228, SB0226, SB0223, SB0229
SBLive! : For CT4670, CT4620, M002/M003, CT4780, CT1140, CT4830, CT4832, CT4870, CT4872, CT4831, CT4871, CT4760, CT4850
SBPCI 512 and SBPCI 256 will probably not work as noted in the foum posts and FAQ but are included anyway:
SBPCI 512 : CT4790, CT4820, SB0150
SBPCI 256 : CT4890, CT4891, CT4893
Here are the old forum posts and FAQ regarding how to do this:
Forum thread:
https://www.hardwareheaven.com/community/thre … -and-live.8229/
And the FAQ:
https://web.archive.org/web/20060708074200/ht … =&threadid=8874
Acquiring the other needed files is up to you until I decide to find them myself.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 7, by rcarkk
Sorry for my ignorance. So this will make possible the instalation of retail drivers on OEM cards?
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 2 of 7, by cyclone3d
Yep, that is part of it.
YMF7x4 Guide
Reply 3 of 7, by matcarfer
cyclone3d wrote:
Well.. this is a blast from the past. […]
ctcomp.zip
Forum thread:
And the FAQ:
Could you help me out? I cant find (or I do not understand on those links) how to install Audigy 2 ZS SB0350 (OEM Dell?) on Win98SE.
Reply 4 of 7, by God Of Gaming
Interesting, gotta try this out, not too long ago I bought a cheap 2 ZS, only to find out its HP OEM so couldnt make it work properly on 98se. I've put it up for sale, to use the money to this time get a proper retail model, but if I can get it to work with this that would be nice.
BTW I have a Audigy 2 ZS Notebook as well, a pcmcia card for laptops, it has a real 2zs chip inside afaik, but no 9x driver on the CD, I wonder if it can be made to work on 98 with this?
1999 Dream PC project | DirectX 8 PC project | 2003 Dream PC project
Reply 5 of 7, by cyclone3d
Get the Audigy 2 ZS CD from here:
http://vogonsdrivers.com/getfile.php?fileid=5 … menustate=43,36
Then copy the whole thing to a folder on the computer you want to install the card on. You will need to first burn a CD or extract the files in the ISO to a thumb drive or whatever in order to get it on the computer running 98.
Then copy ctcomp.exe - linked in my first post to the "\Audio\Setup" folder in the folder where you extracted the install CD to. Then run ctcomp.exe
Then run setup.exe and you should be in business. Make sure to select the vxd drivers. They work better for 9x/ME.
Let me know if this doesn't work and I will figure out step by step instructions and update this post.
Also, I am pretty sure the PCMCIA card will not work in 9x/ME. I tried a bunch of different things and never could get it to work with the drivers for the PCI Audigy 2.
YMF7x4 Guide
Reply 6 of 7, by rcarkk
cyclone3d wrote:
Get the Audigy 2 ZS CD from here: http://vogonsdrivers.com/getfile.php?fileid=5 … menustate=43,36 […]
It didn´t work. No drivers i tried recognized the card. And i tried lots of them. Only KXproject drivers were hable to be instaled. The card works very well with them, so i´m good.
This seems to be an isseu with Audigy cards. The identifier becomes corrupted...i read that somewere.
The K6-III build
Reply 7 of 7, by matcarfer
Do you know that KXproject has no EAX? Let me tell you how I installed the VXD drivers on my Audigy 2 ZE on Win98SE:
I achieved success installing SB0358 Audigy 2 ZS (Dell OEM), on Win98SE and official VXD Drivers with EAX doing other things:
1- I went to AUDIO/DRIVERS/VXD and decompressed VXD.cab on the same folder, so all files are in VXD folder.
2- Then forced the installation going to Device Manager and manually selecting the INF.
3- Card got installed, got sound, but no EAX and of course no applications.
4- Then went to AUDIO/DRIVERS and run CTZAPXX and it let me choose VXD or WDM drivers, so I clickd VXD and success, card got EAX and got properly installed.
5- Installed manually EaxCon-Diagnose-CTEq and some more apps.
6- Success! Could be more happy!
