First post, by HatredSpirit
When I try and run Strike Commander, I get an error message saying
"Protected mode driver is not responding to EMS function calls.
Make sure your EMS driver is not configured with NOEMS option.
If it is, replace the option "NOEMS" with "RAM".
I know DOSbox doesn't use Config.sys, Just wondering if Bootdisks work under DOSbox or if you have a solution, I would be most greatful. Thanks
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
search the forum.
anyway to play it download a cvs version of dosbox (development forum)
Water flows down the stream
