First post, by HatredSpirit
HatredSpirit
Offline
When I try and run Strike Commander, I get an error message saying
"Protected mode driver is not responding to EMS function calls.
Make sure your EMS driver is not configured with NOEMS option.
If it is, replace the option "NOEMS" with "RAM".
I know DOSbox doesn't use Config.sys, Just wondering if Bootdisks work under DOSbox or if you have a solution, I would be most greatful. Thanks
