Reply 940 of 2709, by Falcosoft
- l33t
If possible , please do 32 bit float point in OPL3 GM synth ) beause this synth create noise about -63 dB. This not good and I wantin what would this noise no was be.
As you may have noticed OPL3VSTi is a VST plugin that uses either DosBox or Nuked OPL3 libraries for rendering. None of them supports native 32-bit floating point currently.
So you should convince either the DosBox team or Nukeykt to support it:
Nuked OPL3 emulator
Just a reminder: The primary goal of Nukeykt's OPL3 library was/is to be a bit perfect emulation library of YMF262. So supporting features that the original hardware did not support (like 32-bit floating point rendering) maybe is not something that he is willing to add.
