Reply 20 of 56, by PARUS
w0lf42 wrote:
http://markschamel.com/pictures/diagram.soundblaster.2.png […]
By the way who wrote this tosh "125"? 😁 It's not 125, it's I2S!
And I want to ask. Do you really connect directly 40-pin MIDI OUTPUT and MU80 MIDI INPUT? Does this connection working? I always thought it's impossible but I see on your photos it really is exact. It means that 40-pin MIDI input and output are in current loop standard! Please confirm.
Reply 21 of 56, by w0lf42
That was me. Thanks for correcting me. I've updated my documentation (and this image).
Yes.
Though, I have not had any luck getting the 40-pin MIDI INPUT to accept signal. I'd really like to connect the MIDI OUTPUT on the Yamaha sound card to the MIDI INPUT on my Sound Blaster sound card.
For this to all come together, I've had to fabricate 5 cables/connectors. I believe that I could have purchased the 2 5-pin MIDI to 3.5 mm audio cables. But, at the time that I started this project, there was no standard/specification (but, there is now).
Reply 22 of 56, by PARUS
OK. I'll show a few more wrong/incomplete points. Fix them please.
6) SPDIF2 INPUT
9) SPDIF3 OUTPUT
15) SPDIF1 INPUT
17) SPDIF0 OUTPUT
19) SPDIF1 OUTPUT
22) SPDIF2 OUTPUT
It's exact pinout and in DOS 0.49/1.01 mixers you meet exact these channels "names".
In Creative's Digital DIN connector there are outputs:
SPDIF0 - front
SPDIF1 - cen+bass
SPDIF3 - rear
SPDIF2 is reserved but working condition and you can redirect to it any channel(s) in pure DOS.
Reply 23 of 56, by w0lf42
OK. I'll show a few more wrong/incomplete points. Fix them please. 6) SPDIF2 INPUT 9) SPDIF3 OUTPUT 15) SPDIF1 INPUT 17) SPDIF0 […]
6) SPDIF2 INPUT
9) SPDIF3 OUTPUT
15) SPDIF1 INPUT
17) SPDIF0 OUTPUT
19) SPDIF1 OUTPUT
22) SPDIF2 OUTPUT
Okay, this should be updated too. Thanks, again, for pointing out the errors.
Reply 24 of 56, by w0lf42
Can you write up a diagram with what pin connections you used for each connector of your 40-pin Ribbon mod ?
Here are the diagrams for all of the cables/connectors I made
Reply 25 of 56, by Intel486dx33
You can create and have fabbed your own surface mount pcb. 10 pieces for $10. Then just solder all your connectors to it.
https://youtu.be/g4iiekExXak
Reply 26 of 56, by PARUS
It is worth to create the maximum ultimate version or nothing. I.e. it must consist of all interfaces which present on 40-pin header. Including I2S. I mean I2S input converter ANALOG>I2S/SPDIF>I2S. And input switcher DIGIT/ANALOG. Such board will be better than Creative's Extension 5'25 module.
Reply 27 of 56, by Cosmonal
Guys, please if someone could help me with the flat cable from the X-Fi Platinum (the front panel to soundcard ribbon cable). I've lost mine, could I replace it with an 50 pin SCSI cable? Did anyone know something about it? Thanks in advance!
Reply 29 of 56, by Cosmonal
w0lf42 wrote:
IDE cable cant fit on the X-Fi because of the blocked pin.
The 50 pin SCSI has no blocked pin however. Do you think it will fit on the x-fi case (the front panel case i mean)?
Reply 30 of 56, by w0lf42
I'm not sure what you mean by blocked pin. Perhaps I just don't understand, but from the image on wikipedia, i looks it just has two absent pins:
Reply 33 of 56, by w0lf42
I might be wrong here. But are we talking 40-pin versus 80-pin cables? Yes, the connector might be 40-pin for both, but the cables aren't both 40-pin.
I did a quick ebay search and each 40-pin cable does not have a blocked pin. But, all of the 80-pin cables do.
Reply 34 of 56, by PARUS
w0lf42, )))))))))))))) And you're wrong! 😜
https://bilder.tragant.de/produkte/orig/5110e … 66.01246684.jpg
Most of late 40-wires cables have a key too. I think Cosmonal just haven't found a cable without key.
Cosmonal, yes, 50-pin SCSI cable suits. But do it very carefully, don't make mistake. I mean a cable shift on 5'25 Ext connector relative to main card's connector.
Reply 36 of 56, by Cosmonal
Thanks for the replies guys. I've found an older IDE cable seller here in Brazil. Will try first with the SCSI cable (it's already on the way), if it doesn't fit I'll get and older IDE cable without the key. Thanks Parus and everyone else.
Reply 37 of 56, by PARUS
W0lf42, I want to give you some info. Probably it will be solution.
Take one resistor 1kOhm or 2kOhm and connect through it 23 pin "digital logical input #0" to +5V line. You can take 5V here too, first or second pin. Maybe you'll get usable MIDI input on 40-pin header. Maybe.
Reply 38 of 56, by w0lf42
Thank you! I might try that.
Reply 39 of 56, by PARUS
I did it and got SPDIF input working in Windows (not CD SPDIF but SPDIF IN exactly on 40-pin header).
