First post, by pico1180
So, there I was, going to jump the power header when my metal tool slipped off the power header and touched the adjoining headers. I'm not sure if it made contact with one of the speaker header pins, or one of the key lock pins. All I know is, sparks flew and the system shut down.
On restart the board comes to life, spins fans, makes CPU's hot; all the good things you would expect. But it wont POST.
Of all the things that can kill a board, tell me this isn't one of them. I had big plans for this baby. Tell me she can be revived.
Reply 2 of 15, by SpectriaForce
Try to reset CMOS following instruction in manual.
Don't miss out on the amazing clearance sale at
RETROGAMEPC.COM
CLASSICCOMPUTERSHOP.COM
-> All older stock will be gradually reduced in price until it's sold.
Reply 5 of 15, by luckybob
"Not sure what i should be focusing in on."
well, the idea would be to locate a skidmark. Nothing obvious, so rasz_pl's reply is the likely outcome.
Reply 6 of 15, by rick6
Try to measure the pins that shouldn't be grounded to ground. For example if the HDD led positive side is grounded (which shouldn't be obviously), follow it to the next component and make sure if that it isn't bad.
Most likely they all go straight to the chipset, which at that point i would consider it a lost cause.
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 7 of 15, by meljor
Few years ago I had the EXACT same thing, also with a p3b-f. Killed instantly. I felt pretty stupid for beeing so lazy and not using a proper button (or something with similar function).
After that I always grabbed a simple connector with 2 wires to start motherboards. Now, a few years later I find myself using the screwdriver again..... until the next stupid mistake comes along...
Reply 8 of 15, by colpoz
I'm the third one who did this same stupid thing on my P3B-F!
I remember that after touching the two wrong pins, a small chip on the board flashed and gone away with a nice column of smoke... 😀
But the board didn't die!
it continued to work perfectly, with the only drawback that the only way to switch off the system was to remove the power cable! Turn off from Windows or from holding the power button did't work anymore!
RetroPc I: Asus P3V4X - PentiumIII 1000MHz - 256MB Ram - Geforce3 Ti 200 - SLI VoodooII 12MB - Aureal Vortex2 - HDD 80GB - Win98 SE
RetroPc II: Asus P5A - K6-2 333MHz - 64MB Ram - Geforce2 MX - Voodoo 4MB - Soundblaster AWE64 - HDD 13GB - Win95
Reply 11 of 15, by Cyrix200+
It looks to me there is some burn damage on the upper left pin (PWR)? You should check the backside of the board also (or do you have a picture?). Best case scenario there is a simple short somewhere.
Do you have a POST analysis card?
Reply 13 of 15, by rasz_pl
colpoz wrote:
LOL! […]
now that changes things considerably, maybe there is something between pins and chipset (transistor/TTL gates)
Reply 14 of 15, by varrol
rasz_pl wrote:
colpoz wrote:
LOL! […]
I had that behaviour on this mobo when running damaged RAM + sometimes it was doing a reset on power button press. Of course those are old dusty stuff and there might have been another reason besides bad memory (cause I cleaned up it carefully before finding out about the memory).
Asus CUBX-E | P3 1GHz | 384MB | Radeon 9200 | CT4170
Asus P5A | P55C 200MHz | 256MB | TNT | CT3600
Asus P3B-F | P3 600MHz | 512MB | GF2MX400 | YMF719E-S
AOpen AX6B+ | P3 1GHz | 1GB ECC REG | FX5200 | CT4500
Reply 15 of 15, by HanJammer
If it's a matter of 'zapped chipset' then the easy solution is to replace the chipset. Not as hard or expensive as you may think, and there's plenty of cheap/broken BX motherboards you can use as donors.
For sale (2019.12.01 - new items!!!): 8088, 286 stuff | 386, 486 stuff | Socket 5-8 stuff | Old HDDs and 5.25" FDDs
