Reply 29940 of 52786, by imi
good news and bad news...
so I got my first desktop case some time ago, this one:
103.09 KiB
and I got another one today:
83.04 KiB
notice any similarities? what are the odds 🤣
also got another oddity drive:
63.1 KiB
someone please stop me 😁
...and now for the bad
I wanted to make this a surprise post at first... like "guess what's inside this case" but then I got kind of demotivated upon opening it up... I primarily got it for the case itself and all the disk drives.
it's some kind of apple II? clone... unfortunately it arrived completely busted, the package itself looked fine from outside, but apparently it got smashed and shaken around quite a bit... most of the expansion cards fell out and rattled around inside, cables got ripped off, loose ICs laying around inside the case, this has to have gone through quite some abuse while in transit.
unfortunately the case is also quite damaged, the metal is bent quite a bit in some places and the screws holding the front piece all got ripped out, partly still attached to pieces and the front is chipped all around, it's just being held on by the drives and a cable.
I hope the disk drives are still ok 🙁 one of the closing mechanisms doesn't seem to close correctly.
154.53 KiB
272.08 KiB
I hope I can still salvage most of it.
Reply 29941 of 52786, by MCGA
^^^Wow, that sucks! Hopefully you can fix it! An Apple II that looks like a old PC? O.O
I got these things a couple of days ago for frrrrrrrrrrrrrrreeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. 😁
-IBM Model F AT keyboard - ~i~ AHHHHhhhhHhHhHHHhhhhHHHHHH!
-IBM RS/6000 43p.
-IBM Tape backup enclosure -- I'm re-purposing this as a mini PC, ideally a MISTR FPGA.
I passed on the GIANT IBM f50 server. It was just toooo big. Its power supply was about the same size as my current PC. 😲
I need to pull the keyboard apart to do a full cleaning, but I did thoroughly clean the outside and wash all of the keys. Overall it's in great condition. There is a tiny bit of corrosion on the metal below the keys which I want to properly address. I only dabbed it with vinegar while cleaning.
139.2 KiB
The 43p boots into AIX. I don't have the password, but even if I did have it, I am absolutely CLUELESS about this OS. I've never used it and have no idea what to even do with it. Luckily it has a video card. I learned that many of these were terminals.
132.05 KiB
Reply 29942 of 52786, by dionb
MCGA wrote:
^^^Wow, that sucks! Hopefully you can fix it! An Apple II that looks like a old PC? O.O […]
JEALOUS!!!! 😳
Not terminals, they were headless and required terminals. As for AIX - it's Unix, use it for whatever you would otherwise use Unix for - playing Nethack or serving stuff 😉
Reply 29943 of 52786, by MCGA
I saw the add for the keyboard after the RS6000 and it just happened to be the same guy. I was only going to grab they keyboard, but I couldn't resist the IBM when I saw it in person.
Outside of the terminal window and power shell for things like SSH, I don't have much experience with Unix either. I'll have to look into resting the password. I hope there's a way? I was pondering reinstalling AIX, but then I read that it's not plug and play, so more work/research than I want to put into this at this time. I'd happily give this RS/6000 to someone that could make better use of it, but they'd have to drive to pick it up, or setup the postal. 😀
Reply 29944 of 52786, by imi
free is the best kind of payment 😁
it's the same as this board apparently: https://www.oldcomputr.com/wp-content/uploads … rboard-7755.jpg
idk if that was a diy job or a commercial clone, the case seems to be purposfully made for it though.
I'm not that familiar with apple/clone hardware, so I'm not sure yet what to do with it... as the case is going to need extensive repairs... and it doesn't hold regular PC hardware... use it for a sleeper PC maybe?
or would it be worth it to restore this clone?
Reply 29946 of 52786, by dr.ido
Your clone is something more than a standard apple 2 clone. Apple 2 does not use standard PC type 34 pin floppy drives. The floppy drives on the right hand side appear to be standard apple clone floppy drives connected to a standard clone apple 2 floppy controller. The standard floppy drives on the left hand side are completely out of place in an apple 2 - what card are they connected to?
Reply 29947 of 52786, by yawetaG
Yamaha XG MIDI file CD-ROM with 100 MIDI files (probably classical music), some with PLG-100VL support:
129.45 KiB
Yamaha XG MIDI file Karaoke CD-ROM with 50 MIDI files:
75.59 KiB
Bundle of Japanese Roland SC-88ST manuals (not all pictured) and CD-ROMs:
74.38 KiB
The CD-ROM on the right is an older version of a CD-ROM I already owned. The one I had was from 1999, this one is from 1996. Despite looking the same, they feature different programs. This one has MIDI files, Windows 95/NT drivers for IBM and NEC PC98, Roland Remix, Doremix, NetJukebox, SingerSongWriter Lite, Cakewalk Demo, and Cakewalk HomeStudio.
The CD-ROM on the left is a Demo CD-ROM with MIDI files, Score Grapher Lite, Roland dtm database, GMGakki, Edirol stuff, Hyper Groove Demo, NetJukebox, SGL demo, and a Roland digital catalogue.
(It actually looks like the 1999 CD-ROM is a condensed version of both of the 1996 CD-ROMs).
Also included was a mint, sealed copy of MOTU Unisyn for Windows 1.2 "Roland Edition", which is a Windows 3.x/Windows 95 software librarian for tweaking gear via MIDI, with support for a crapton of Roland gear (A880, Alpha Juno 1, Alpha Juno 2, CM-32P, CM-32L, CM-64, D-10, D-20, D-110, D-50, D-550, D-70, DEP-5, GM-70, GP-8, GR-50, JD-800, JD-990, Juno 106, JV-35, JV-80, JV-880, JV-90, JV-1000, JV-1080, JX-8P, MKS-20, MKS-50, MKS-70, MKS-80, MT-32, PAD-80, R8-M, R-8, SC-33, SC-50, SC-55, SC-55Mk.II, SC-155, SC-88, SC-88Pro, U110, U220, U20, XP-10) 😎 . This CD was a surprise, as it was inside one of the manuals.
Reply 29949 of 52786, by cyclone3d
Marmes wrote:
Does anyone know where can I buy a XR385/DB60XG? Or anyone has a surplus and might wanna get rid of it?
There is one on yahoo auctions Japan right now.
I go through buyee.jp.
https://buyee.jp/item/yahoo/auction/w332137825
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 29950 of 52786, by oeuvre
The Dell Optiplex GXM 5133 came yesterday. I paid $90 shipped for this, which is a lot IMO. Still, could've been much worse.
seller's pic
after the retrobright... not perfect but much better!
Pentium 133MHz processor
32MB 72-pin EDO SIMM RAM
1GB IBM hard drive
8X NEC CD-ROM
3.5" floppy
Onboard S3 graphics (1MB)
CNet Pro200WL PCI network card
YAMAHA YMF-719 ISA sound card
added an ISA sound card and a PCI network card
opened up
all cleaned up
closeup of PSU and HDD
dat CD-ROM drive
Planned upgrades - 64MB RAM, larger + faster HD (Quantum FireBall), PCI video card upgrade, possibly a COAST module if I can find one
Reply 29952 of 52786, by Bondi
Cool stuff! Is there a chance that you dump these disks and upload somewhere?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 29953 of 52786, by imi
see, as I said I'm not familiar with apple hardware, I didn't even know apple had special disk drives ^^ I just thought they were regular 360K or 720K drives at first glance.
this is the card the other drives are connected to, also thanks for making me check, judging by how that IC in the bottom left is totally bent out of place and the chipped empty socket I guess the loose IC that was flying around in the box probably belongs here.
278.24 KiB
edit: google led me here http://www.appleii-box.de/H085_AppleIIFDC4.htm
Reply 29954 of 52786, by PTherapist
1 final Games Console purchase for me for the year - I bought an original Xbox. I saw how bad the current state of Xbox emulation on PC was, so just had to get one. No pics as I haven't received it yet, it should arrive with me in a couple of days, so fingers crossed it's in decent condition inside. Comes with a bunch of games already, but I also purchased Splinter Cell for it, for no particular reason... 😉 🤣 😈
I plan to upgrade the HDD eventually. I have a spare 500GB drive that should do nicely, provided it plays nice with my SATA-IDE adapters. If it doesn't, I'll probably just take a chance and purchase an old IDE drive.
I actually received the Splinter Cell game today and ended up playing it for a couple of hours on my Xbox 360.
Reply 29955 of 52786, by Merovign
imi wrote:
You may have a somewhat historical system there! If you had plenty of times you could skim through the old Creative Computing mags on archive.org - they had a lot of ads for Apple II clones in the early 80s, and a column dedicated to them for a while IIRC.
It could also be a homebrew or one of the non-US clones... I would love to have access to some of the output of some of the domestic industries of places like Brazil and France that tried hard to have their own large domestic industries in the 1980s (actually a lot of countries did, I learned some about Norway's last year).
*Too* *many* *things*!
Reply 29956 of 52786, by Warlord
tell you the truth its hard to believe that apple II clone or whatever was damaged like that during shipping. Expansion cards don't get unscrewed and come out on their own and fly around inside of a case. It must of been like that and then whoever sold it shipped it like that because they were dumb.
Reply 29957 of 52786, by luckybob
Not quite retro, but I will be using it outside in my garage.
https://imgur.com/a/Vy1AcNq
Paid $40 for it. Asked if anything was missing, said no. I drive 30 minutes to get it, no feet.
Add $15 for feet.
It should clean up fine, but I'm 100% going to replace the fans. I let this bake outside in the 100F sun for 2 days before I brought it into the garage.
Reply 29958 of 52786, by Windows9566
oeuvre wrote:
The Dell Optiplex GXM 5133 came yesterday. I paid $90 shipped for this, which is a lot IMO. Still, could've been much worse. […]
seller's pic
1GB IBM hard drive
8X NEC CD-ROM
3.5" floppy
opened up
all cleaned up
dat CD-ROM drive
Nice dell you got there
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 29959 of 52786, by hasnopants
I guess I am learning apple ii now... 😁
to go with my apple today, I got some anger...
Current Systems:
DIP40|8088|640K|HERCULESGB102|PCSPKR
DIP40|V20|640K|VGA|ADLIB/TNDY/COVOX
S7|P233MMX|128M|S3ViRGEDX/DM3D|SB16
S370|P600MMX|256M|SIS630/DM3DIIX2|SBLIVE!5.1
S775|P43.4|2G|6800GS|SBAUDIGY
