First post, by ckorodenis
I have a problem running the application on macos, Dosbox is running normally, I have also set the root directory correctly. Program under windows works perfectly without a problem. In windows, I run an application using a PS.bat file with this code
@echo offC:cd\cd \f.3if not exist C:\f.3\PS.3\USER.U97 copy C:\f.3\work\USER.U97 C:\f.3\PS.3\USER.U97del C:\f.3\work\RUN*.TXTSTART C:\f.3\PS.3\2.DAT\PS_RES.EXEC:\f.3\DOSBox\DOSBox.exe -conf C:\f.3\DosBox\DosBoxPS.cfg
In macos I tried different variants, I tried to run PS.bat file in dosbox via context menu, but unsuccessfully. After editing the PS.bat file, you will occasionally receive an error that is not a DOS application. It always shows the boot procedure, but nothing turns on, it ends up in the Dosbox. Also, nothing happens after you edit a .bat file. Do you have any idea how to solve the problem? I can provide files, including codes.
