First post, by ckorodenis
Hi,
I have a problem running the application on macos, Dosbox is running normally, I have also set the root directory correctly. Program under windows works perfectly without a problem. In windows, I run an application using a PS.bat file with this code
@echo off
C:
cd\
cd \f.3
if not exist C:\f.3\PS.3\USER.U97 copy C:\f.3\work\USER.U97 C:\f.3\PS.3\USER.U97
del C:\f.3\work\RUN*.TXT
START C:\f.3\PS.3\2.DAT\PS_RES.EXE
C:\f.3\DOSBox\DOSBox.exe -conf C:\f.3\DosBox\DosBoxPS.cfg
In macos I tried different variants, I tried to run PS.bat file in dosbox via context menu, but unsuccessfully. After editing the PS.bat file, you will occasionally receive an error that is not a DOS application. It always shows the boot procedure, but nothing turns on, it ends up in the Dosbox. Also, nothing happens after you edit a .bat file. Do you have any idea how to solve the problem? I can provide files, including codes.
Reply 3 of 6, by ckorodenis
Line number 8
can be removed from the code, under windows PS_RES.exe serves only as a file scan and backup service. It is not needed to run the application in DoxBox. The application will run under windows also using a modified PS.bat with code
@echo off
C:
cd\
cd \f.3
this code in the PS.bat file is absolutely enough for the application to run without error in DosBox on windows 😀
No, under windows I run the application only using PS.bat file, but unfortunately I do not know how to run the application under MacOS, so I tried every variant
I need some advice on how to edit the PS.bat file or how to run this application properly under MacOS.
Reply 4 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You cannot use the batch file on OS X.
Look at the contents of the dosboxps.cfg.
Mount the folder that the cfg is in on OSX
(e.g. mount c /users/ckorodenis/desktop/ps)
and then change to c in Dosbox and run the exe that is referenced in the dosboxps.cfg
C:
Ps.exe
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 6, by ckorodenis
In the dosboxps.cfg file, this code is written down in windows.
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
mount C: C:\
C:
cd C:\f.3\ps.3
SET LANNODE=
SET DOSBOX=1
SET FANDOVRB=80
SET FANDWORK=C:\f.3\WORK\
SET FANDCAT=C:\f.3\PS.3\
C:\f.3\OK\OK /I /K /$ /E /0
C:\f.3\DPAKBD.COM /T20 /I
C:\f.3\UFAND PS
exit
On MacOS, I have modified the file to this code, the folder is located on the desktop
[autoexec]
mount C: /Users/Mir/Desktop/
C:
cd C:\f.3\ps.3
SET LANNODE=
SET DOSBOX=1
SET FANDOVRB=80
C:\f.3\UFAND PS
exit
The PS.exe file does not exist, I cannot determine which .exe actually runs under windows. There are many in the folder. Can I find out which .exe file runs DosBox in windows? When I run the PS.bat file?
Adding screeshot desktop in windows, after running PS.bat, DosBox opens and within one second the program starts correctly ... But I don't know what .exe is opening
    212.23 KiB
    291.3 KiB
    283.16 KiB
Reply 6 of 6, by Dominus
DOSBox Moderator
Just put your modified code after c: in a batch file (ps3.bat) on your desktop.
When dosbox starts do
Mount c /users/mir/desktop
C:
Ps3.bat
