First post, by Almoststew1990
- Oldbie
I want to make a Windows 98SE PC with the following:
Slot 1 Motherboard 650MHz
AGP Nvidia MX440 (Primary)
PCI Voodoo 3 2000 (Glide only)
ISA AWE32 (Secondary/DOS) IRQ 5
PCI SB Live (Primary) - usually goes on IRQ10/11
I'll have all parallel, serial, even USB disabled in the BIOS so I don't think I'll have IRQ conflicts... if set up correctly.
For sound I was wondering if I could do some kind of line-in / pass through option here? But I can just plug both cards into my amp in separate aux ports and switch between the two on my amp if needed.
For switching between the graphics cards, is there a way to avoid having to go around the back of the machine and "manually" switch the VGA cable between the two cards?
Is this build actually possible?
