Is this build possible?
First post, by Almoststew1990
I want to make a Windows 98SE PC with the following:
Slot 1 Motherboard 650MHz
AGP Nvidia MX440 (Primary)
PCI Voodoo 3 2000 (Glide only)
ISA AWE32 (Secondary/DOS) IRQ 5
PCI SB Live (Primary) - usually goes on IRQ10/11
I'll have all parallel, serial, even USB disabled in the BIOS so I don't think I'll have IRQ conflicts... if set up correctly.
For sound I was wondering if I could do some kind of line-in / pass through option here? But I can just plug both cards into my amp in separate aux ports and switch between the two on my amp if needed.
For switching between the graphics cards, is there a way to avoid having to go around the back of the machine and "manually" switch the VGA cable between the two cards?
Is this build actually possible?
Reply 1 of 7, by Jo22
Almoststew1990 wrote on 2020-03-13, 19:44:
Hello, yes, there are KVM switches that can be used for this.
Originally, these devices were meant to operate two PCs with a single set of keyboard, video and mouse.
https://en.wikipedia.org/wiki/KVM_switch
Reply 2 of 7, by kolderman
Problem is win98 generally doesn't like two display adapters, you might be installing drivers every boot. Why not just a voodoo2?
Reply 3 of 7, by Horun
kolderman wrote on 2020-03-13, 20:22:
Agree !! Even Win ME does not like dual cards unless they are exact same.
Reply 4 of 7, by chinny22
I've a Ti4600 paired with a V3 and was surprised how well it worked in Win98SE? Only difference is I have a dedicated screen attached to each card.
No driver issues at all, just set the primary card to AGP in BIOS and the desktop behaves just the same as a multi screen setup in later windows versions.
Only problem so far is powerslide refuses to detect glide support unless I disable the Ti4600 in device manager. Every other game in my catalogue correctly picked the correct card depending on API.
If your screen has multiple inputs, say vga and DVI you can attach each input to a different card and use the monitors input select to switch between the 2.
This same PC had both SBLive and a ISA Sound blaster. I didn't even bother disabling the ports and only the 2 game ports conflicted so it's definitely do-able
If both soundcards are setup in windows you could run the line out of the live to the line in of the AWE (not the other way as that wont work in dos) but your amp method is better
Reply 5 of 7, by zyga64
chinny22 wrote on 2020-03-17, 14:18:
It should be possible. Using PARUS's Live! mixer. link
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 6 of 7, by red_avatar
I want to make a Windows 98SE PC with the following: […]
I take it you own the Voodoo3 2000? Because otherwise, just get a Voodoo2 12MB. Similar performance, but it has pass-through. I use it in my own P3 600 system like this.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 7 of 7, by Almoststew1990
Yes I have the voodoo 3 already. However with our office now all home working and my partner also home working I am now sharing desk space and my monitor collection so this project is now on hold;
