First post, by andreja6
So recently I tried installing 95 OSR 2.5 onto a K6-2 500. It has been absolute hell, with the k6 issue, and then supplemental updates, chipset drivers for the VA-503+, and so on
Now i'm almost done, it all works, I installed DirectX 8.0a, DCOM95, and so on, but the Rage 128 just refuses to work. It installs, shows up as Rage Fury, and then 1. doesn't boot and 2. when it does boot, it just gives an error saying the display is not configured correctly.
Any help?
I have 256MB RAM, a K6-2 at 500MHz with the K6 patch, Rage 128 AGP part number 109-51900-01 with 32MB VRAM, on a VA-503+ board, and MVP3 chipset
