Reply 220 of 440, by feipoa
Well, I've gotten the testbed setup now and did a quick test with an SXL-33. Report attached.
CPU-Z reported the motherboard as an ECS Elitegroup, but it is a Daewoo AL486V-D. Everything else appeared correct.
I'll report back with benchmark scores after I fine tune the BIOS settings. I should also try running it with L1 disabled to ensure CPU-Z reports L1 as disabled.
    SXL-33-W95.rar
    1.2 KiB
    66 downloads
Reply 221 of 440, by CuPid
feipoa wrote on 2020-04-16, 14:03:
Does running CPU-Z in NT4 provide any additional information over running it in Win95?
No, the version is really targeted for win9x.
Thanks for the test on the SXL, please save the TXT reports rather than the HTML, the HTML do not contain the registers outputs.
I need a vacation.
Reply 222 of 440, by TechieDude
Just tried it again in my Socket 5 PC. It's a success! Haven't tried to see if it still suffers from K5 crash yet, but I'll try soon.
Edited that out because it was unnecessary here. Sorry.
    USER.txt
    11.41 KiB
    58 downloads
Reply 223 of 440, by feipoa
Test results with the SXL2-50 installed and running at 2x25=50 MHz and a Cyrix FasMath CX-83D87, running at 25 MHz.
CPU-Z is reporting the incorrect multiplier. Is CPU-Z able to read the Configuration Control Register 0 (aka, CCR0) bit 6? If it is set high (1) that means the 2x multiplier is active, if set low (0) the CPU is in 1x mode.
202.48 KiB
Here are the benchmark results.
188.92 KiB
Screenshot indicating the wrong motherboard brand.
182.64 KiB
Report file in text format.
SXL2-50-w95.txt
2.77 KiB
62 downloads
Reply 224 of 440, by CuPid
TechieDude wrote on 2020-04-16, 21:01:
Great, thanks for the feedback.
feipoa wrote on 2020-04-17, 06:42:
Ah yes good point, I add this and update the binary. Thanks !
Your BIOS string is
40-0100-001131-00101111-080893-ALI1429
and according to https://www.wimsbios.com/aminumbers.jsp, 1131 is ECS. Weird.
I need a vacation.
Reply 226 of 440, by CuPid
I've added the 2x multiplier detection from CCR0. I wonder if the switch 1x / 2x works dynamically, do you have a tool that allows to change CCR0 ?
http://download.cpuid.com/betas/cpuz_w95.zip
I need a vacation.
Reply 227 of 440, by feipoa
Yes, I can change it in DOS. I will can switch it back to 1x and ensure that CPUID is behaving. I also want to disable L1 to ensure CPUID shows the cache as disabled.
Reply 228 of 440, by appiah4
CuPid wrote on 2020-04-16, 12:54:
appiah4 wrote on 2020-04-16, 12:38:
It's a Cyrix 6x86MX PR233 running on Windows 98SE
Ah, there are no MSR read on that system, it must be something else.
Can you please copy that cpuz.ini in the same directory as cpuz_w9x.exe, and tell me if the program starts this time ?
I tried this .ini with the below latest beta executable and it still crashes.
This particular system also crashes when loading SpeedSys and requires the /SP switch to disable PCI/ISA detection.
It might be related?
Reply 229 of 440, by CuPid
appiah4 wrote on 2020-04-17, 10:19:
Yes definitely, but PCI detection was disabled in the ini.
By disabling ISA I wonder if it would disable the DIRs registers reading, that would explain a lot. I have no flag in the ini to disable that, but it could be easily and quickly removed for testing purpose. I keep you posted.
I need a vacation.
Reply 230 of 440, by appiah4
CuPid wrote on 2020-04-17, 10:25:
Sorry for the inconvenience but if you are willing to do something about it and come up with another binary I'm ok with trying it out..
Reply 231 of 440, by feipoa
I have verified that CPU-Z shows the correct core speed and multiplier when I change the multiplier in software for the SXL2-50. However, when I disable the L1 cache entirely, CPU-Z is still reporting it as 8 KB, 2-way set associative. I think it should be greyed out entirely, or listed as "disabled".
Is CPU-Z able to display the graphic card information for VLB cards? Everything in the Graphics tab is greyed out.
Reply 232 of 440, by red-ray
The latest CPUZ 9x had broken reporting for my 9980XE and many other systems. Reporting x12 and 30000MHz is clearly impossible and I see similar on most recent systems.
I also think IVB-E is 22nm rather than 21nm, see https://en.wikipedia.org/wiki/List_of_I ... erformance
    RXI.txt
    270.42 KiB
    74 downloads
    41.72 KiB
    RED.txt
    405.76 KiB
    53 downloads
    34.28 KiB
Reply 233 of 440, by CuPid
feipoa wrote on 2020-04-17, 10:44:
Is CD bit of CCR0 set to 1 when L1 is disabled ?
No, I don't have the smallest idea about how to detect VLB or ISA cards.
I need a vacation.
Reply 234 of 440, by feipoa
I don't know. This is my control screen:
214.29 KiB
And these are the registers I can read from CTCHIP34:
;********** Cyrix/Texas 486SLC/DLC in CX486.CFG********************
INDEXPORT=22h
DATENPORT=23h
FLUSH=INVD
INDEX=C0h; Configuration Control Register 0
BIT=7 ;0/1 (Suspend) /SUSP input and /SUPSA output
BIT=6 ; (CO) Cache-Organisation
0= 2-Way
1= direct mapped
BIT=5 ;0/1 (BARB) Flush Cache every HOLD
BIT=4 ;0/1 (FLUSH) /Flush input pin (DLC:E13, SLC:30)
BIT=3 ;0/1 (KEN) /KEN input pin (DLC:B12, SLC:29)
BIT=2 ;0/1 (A20M) /A20M input pin (DLC:F13, SLC:31)
BIT=1 ;0/1 (MC1) 640K-1M non-cacheable
; (Bug in A4/A5 Stepping!)
BIT=0 ;0/1 (NC0) First 64KB always not cacheable
; (Real/Virtuell)
INDEX=C1h; Configuration Control Register 1
Bit=0 ; 0/1 (RPL) output pins /RPLSET and /RPLVAL
INDEX=C4h; Non Cacheable Region Register (Default=00h);
BIT=7654321 ; A31 - A24 of starting address Region 1
INDEX=C5h; Non Cacheable Region Register (Default=0Ah);
BIT=76543210 ; A23 - A16 of starting address Region 1
INDEX=C6h; Non Cacheable Region Register (Default=06h);
BIT 7654 ; A15 - A12 of starting address Region 1
BIT=3210 ; Size of non-cacheable Region 1
INDEX=C7h; Non Cacheable Region Register (Default=00h);
BIT=7654321 ; A31 - A24 of starting address Region 2
INDEX=C8h; Non Cacheable Region Register (Default=0Ah);
BIT=76543210 ; A23 - A16 of starting address Region 2
INDEX=C9h; Non Cacheable Region Register (Default=06h);
BIT 7654 ; A15 - A12 of starting address Region 2
BIT=3210 ; Size of non-cacheable Region 2
INDEX=CAh; Non Cacheable Region Register (Default=00h);
BIT=7654321 ; A31 - A24 of starting address Region 3
INDEX=CBh; Non Cacheable Region Register (Default=0Ah);
BIT=76543210 ; A23 - A16 of starting address Region 3
INDEX=CCh; Non Cacheable Region Register (Default=06h);
BIT 7654 ; A15 - A12 of starting address Region 3
BIT=3210 ; Size of non-cacheable Region 3
INDEX=CDh; Non Cacheable Region Register (Default=00h);
BIT=7654321 ; A31 - A24 of starting address Region 4
INDEX=CEh; Non Cacheable Region Register (Default=0Ah);
BIT=76543210 ; A23 - A16 of starting address Region 4
Show last 4 lines
INDEX=CFh; Non Cacheable Region Register (Default=06h);
BIT 7654 ; A15 - A12 of starting address Region 4
BIT=3210 ; Size of non-cacheable Region 4
I have a dozen more DLC/SXL software apps, but it would take some time to go through them all to see if any can read CR0.
EDIT: Note that CCR0 != CR0
Reply 235 of 440, by CuPid
appiah4 wrote on 2020-04-17, 10:38:
On the contrary, it is always interesting to figure out what can be wrong.
Here is a version without DIRs reading. If it works, you can eventually remove cpuz.ini (that results in setting all flags back to 1).
http://download.cpuid.com/betas/cpuz_w95_noisa.zip
feipoa wrote on 2020-04-17, 11:46:
Yes I just realize my mistake, CD is a bit of CR0, not CCR0.
I need a vacation.
Reply 236 of 440, by appiah4
CuPid wrote on 2020-04-17, 12:08:
OK I downloaded this, I will try it out tonight and let you know CuPid.
Reply 239 of 440, by feipoa
CuPiD> Is there another revision of CPU-Z you wanted me to test on the SXL-50 for the case of L1 being disabled? If not, I'll move onto another CPU on your wish list.
