First post, by appiah4
- l33t++
Is there a special kind of Slocket/Slotket required for running Tualatin/Tualeron CPUs in Slot-1 motherboards, or do Coppermine Slocket/Slotkets simply work if you have a BIOS that supports it and a voltage regulator capable of 1.3V all it takes?
Asking because I have a P2B-F with a HIP6019BCB regulator, and I want to know if the slockets I have at hand will be fine for running a Celeron 14oo on it.
